RV.Net Open Roads Forum: AC Water on top of RV
mittshel
Lake Havasu City, AZ
Posted: 08/15/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
The water that drains off the AC runs down the front cap of our fifth wheel. Has anyone diverted that water so it runs off the side of the RV? All input appreciated. Thank you. Betsy.
Betsy
garyemunson
Reno, Nevada
Posted: 08/15/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
This stuff is small, sticks well, and does not look out of place. Can be used to alter the condensate water's path.
https://www.homedepot.com/p/Legrand-Wiremold-CordMate-Cord-Cover-5-ft-Channel-White-C10/202059078
mittshel
Posted: 08/15/21 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you, Gary.
bgum
South Louisiana
Posted: 08/15/21 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
If your rig is not level front to back it will do that. Most rigs have a drain hose exiting somewhere near your driver side tires. If that is plugged up then it will runn of on the roof and sometimes inside. Drain hose is about size of child's finger. They get plugged by muddaubers and spiders.
Yooper-Jim
Michigan & Texas
Posted: 08/15/21 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Typically you don't quite level your rig, but leave a very tiny pitch down on the driver's side. A/C condensation then drains to the rain track on that side.
Edd505
Elephant Butte, NM
Posted: 08/15/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
You should have gutters on both sides and each should have an end that looks something like this.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
mittshel
Posted: 08/15/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I guess we would have to reset the auto levelers. Thanks for each idea.
schlep1967
Harrisburg, PA
Posted: 08/16/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I did the cheap and easy fix. I had a tube of caulk laying at the house. I ran a heavy bead of caulk from the AC where the water comes out to the back corner of the trailer. The water follows the caulk right down to the edge of the trailer and over into the rain gutter.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Sandia Man
Rio Rancho, NM
Posted: 08/16/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
We always use manual leveling as our auto leveling system appears to be intoxicated when it decides we are level, been too lazy recalibrate it. Again we prefer using manual mode and leave it a tiny bit lower on one side if anticipating prolonged AC usage, totally unnoticeable to those within the coach.
valhalla360
No paticular place.
Posted: 08/16/21 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
This is what we've always had on all 4 corners.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
