RV.Net Open Roads Forum: Tech Issues: Dometic 9100 Awning probem
 > Dometic 9100 Awning probem
dougrainer
Carrolton, Texas
Posted: 08/16/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Bunklash wrote:
Dougrainer/fj12ryder........ Afraid not, (reminds me of the the joke with the punchline, 'a frayed knot'). The piece the set screws seat into does not spin on the shaft. That piece is fast to the motor shaft, and the motor shaft will not turn. Once the set screws are removed should that coupling be free from the motor shaft? That's the only way I can see it would work without shearing off the wires. I sure could use some help 'cause we're supposed to be leaving in two days, and rough weather is heading this way. (In north GA, awaiting tropical storm Fred's arrival).
BTW, I ain't the sharpest tool in the shed, but my wife thinks I'm the shiniest! Shhhhh, don't tell her!
Do you HAVE the actual manual for the 9100? You are hung up on those 2 wires. DON"T BE! What I posted is verbatim from the manual release for a locked motor from the 9100 owners manual, and yes I have done the procedure many times. Page 8. Doug
https://www.dometic.com/externalassets/d........00-power-patio-awning-hardware_73709.pdf
