RV.Net Open Roads Forum: Truck Campers: Anyone with 12v Air Conditioning Experience?
 > Anyone with 12v Air Conditioning Experience?
Page of 6
Kayteg1
California > Nevada
Posted: 08/28/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
burningman wrote:
It’s similar with campers. They come with seemingly oversized units for a reason.
Don't know about oversized.
My 12' Lace had 13.5 k BTU unit and when we camp in 120's the AC running all the time was just on the edge of keeping us in comfort.
We were good in the center, but close to the walls you felt the heat.
Opening any cabinet was like opening working oven.
We had afternoon shade, so with night cooling down to 105F made the cabover good enough for sleeping.
adamis
Northern California
Posted: 08/28/21 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
HMS Beagle wrote:
adamis wrote:
Here is an interesting test. Granted, it was done in ideal conditions but still quite impressive. The 100ah Victron LiFePo4 battery lasted for 2 hours and 40 minutes. They are supposedly going to do an outdoor test tomorrow.
https://youtu.be/2LL7lE4wXvs
Interesting test, even if they presenter is completely clueless on just about every aspect of it. Since it was in a closed room with the thermostat set below ambient, it would have run the whole time without cycling (and would be heating the room a bit). I doubt it would use much more outside in hot temps, the high side pressure will increase just a bit. If you added 400 watts of solar you could keep it going pretty much as long as the sun shines.
Yeah, I think for 95% of cases, this scenario works pretty well. Initially I was thinking I would need 400AH of batteries but in reality, I may just need 400w+ of solar (already have 200w) and I should be okay for most of what I would need.
I am interested to see the outside test results.
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
burningman
Seattle, WA USA
Posted: 08/28/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, that’s exactly what I’m sayin’!
If you go by a residential BTU needed for how many cubic feet chart, it seems like campers have oversized ACs, but… they don’t!
The reason is what you described.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Kayteg1
California > Nevada
Posted: 08/28/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I think the same will apply to furnace size or fuel supply for those who camp on the snow.
Most of my camping years I took my family to Sierras in CA, where on elevations above 4000' and parking in the shade I never need AC.
We spend days on the beach, or boat, while evenings at campfire.
The battery bank in RV would last several days, even when making morning coffee on inverter power. Those were days when affordable solars did not exist, so on day 3 I would fire generator to recharge the battery.
5 gallons of propane would last for 80 days of camping, with warming water for showers and lot of cooking.
Than beside camping in high heat I posted above, I remember nights on snow, where with big propane tank, my motorhome would discharge house batteries at 2 AM.
There is no simple way to tell what you will need without reading next week forecast for planned site.
But my idea is that when I install something, I want it to work for most of the conditions, not just for 1 weekend.
Hemi Joel
Minnesota
Posted: 08/28/21 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
You'll need a very hefty set of cables to get 120 amps all the way up to the roof.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
HMS Beagle
Napa, California
Posted: 08/29/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
The Dometic 2000 uses about 40A max, so still big cables but certainly manageable. #6 would be enough.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Kayteg1
California > Nevada
Posted: 08/29/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
We have lot of "electricians" here, who will apply house building codes to automotive designs.
They are not the same and I see a lot of car wiring carrying 20 amp over wire who looks like #16.
My multimeter has about #20 wires and during testing I had 25 amps in it.
Wire in cars are much shorter than in house and they have much better cooling, where risk of fire is much lower, so the only reason for installing heavy wire on solar would be voltage drop.
Than if you install solar regulator close to the battery, that would solve voltage drop as well.
I am not trying to be electrician here, but doing mechanical work I was forced to do lot of electrical as well.
3 tons
NV.
Posted: 08/29/21 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, Dometic also offers the same unit in a 24v version…
3 tons
stevenal
Newport, OR, USA
Posted: 08/30/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1,
Have you checked the RVIA electrical codes? I was impressed on how conservative they are. You are correct regarding wiring in cars, but I believe the topic here is wiring in TCs.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
Kayteg1
California > Nevada
Posted: 08/30/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
The issue was solar wiring.
This year I bought 3000 W inverter, who came with about 18" of connecting cable.
So for 400 amp potential current, I measured the attached cables to be.... wait for it..... #8 gauge.
What RVIA says?
Page of 6
