RV.Net Open Roads Forum: Tow Vehicles: Oops
Search only in Tow Vehicles
 > Oops
4x4ord
Alberta
Posted: 08/16/21 12:03am Link  |  Quote  |  Print  |  Notify Moderator
I forgot to back off the brake controller setting before sending my truck and fiver down the road with an inexperienced driver at the wheel. I was following along behind and noticed some very black long skid marks on the road just before turning into our campground. One quick look at my trailer tires confirmed my suspension.
2021 F350 SRW Platinum short box 4x4.
B&W Companion
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 08/16/21 04:28am Link  |  Quote  |  Print  |  Notify Moderator
We pay for our education. Glad it was only that and thanks for sharing.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
valhalla360
No paticular place.
Posted: 08/16/21 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Check that the brakes themselves aren't the issue. Did they seize up?
Even at max and locking up when braking...they should still release once the driver takes his foot off the brakes.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
pitch
NY
Posted: 08/16/21 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Yep he sure skidded those tires for a distance. There should have been smoke rolling, he ain't got no mirrors?
Valhalla is correct though, your controller can be set to the max and this will not occur,you have a frozen brake.
4x4ord
Alberta
Posted: 08/16/21 06:46am Link  |  Quote  |  Print  |  Notify Moderator
^^^^ The brakes are releasing fine. The controller was set to 7.5 and should have been set to 6.0. I took the truck for a spin afterward and was surprised to discover how the brakes felt normal set at 7.5 during a typical brake application yet it didn’t take much more than normal effort to get the wheels to lock up.
jdc1
Rescue, Ca
Posted: 08/16/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Reminds me of the rime my nephew pulled the pin on the brake disconnect on my dump trailer. I asked why he did it. His said he wanted to see what would happen. 1/2 a block of skid marks is what happens. He never did that again. 20 years later, I gave him that same trailer.
JIMNLIN
Oklahoma
Posted: 08/16/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
I pull several different size trailers with the same truck. I've flat spotted my 32' 5th wheel rv tires tires more that once because I forgot to back the controller off after pulling a heavier trailer.
And of course pulling one of my empty flat decks and hitting the first stop signs after pulling my rv trailer. This left long skinny black marks as the tires (no load) rode the center of the tread.
All the many rv and non rv trailers I've owned I R&R the trailers brakes with maybe heavier wire....get rid of all clamp type connectors...make solid connections....make sure each brake is receiving the correct amps/etc.
Doing so with the brake controller set high enough it can slide the tires even at max axle loads.
* This post was edited 08/16/21 08:11am by JIMNLIN *
FishOnOne
The Great State of Texas
Posted: 08/17/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
I hate it when that happens.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
ACZL
UPstate,NY
Posted: 08/18/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Brakes work !
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Crespro
SoCal
Posted: 08/18/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hi. I have the same weight fifth wheel and run 7.0 on an F-250. Seems fine, but you suggest 6.0. I know there is a test at 20mph. Is that how you set your unit at 6.0?
Thanks!
Crespro 2021 Grand Design 310GK-R, 2020 F250LB, 7.3L, 4.30, Reese 27K
 > Oops
