RV.Net Open Roads Forum: Tow Vehicles: Towing with 2004 Lincoln Aviator
Search only in Tow Vehicles
 > Towing with 2004 Lincoln Aviator
rg3
souutheast
Posted: 08/16/21 11:45am Link  |  Quote  |  Print  |  Notify Moderator
I have recently purchased a new old Gulf Aero Light 19 ft bumper pull camper. The camper weigh 4005 LBs dry and about 4500 loaded with gear but not fresh water. I have a 2004 Lincoln Aviator with a 4.6 L 281 V8 dohc with 110,000 miles. The tow rating on the TV is 7000 lbs. Can I successfully pull the camper, it seems a bit sluggish? Could sure some advice.
Tyler0215
Iowa
Posted: 08/16/21 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
If it feels sluggish you'er already pulling the trailer. Of course it feels sluggish. Thats a lot of weight for a mid size SUV. I wouldn't do it, but you may have lower standards.
Posted: 08/16/21 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, not a problem at all for that vehicle and size of trailer.
2017 Heartland Torque T29
camperfamily
New Jersey
Posted: 08/16/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
If the vehicle is in good condition and well maintained just take your time. Your not going to win any races, nor should you want to. A more robust TV would be great, but if you are safe I'd go camping. Not everyone can afford a new vehicle.
That said, I do think 7k is optimistic for a tow rating for a Aviator (basically a explorer). I pulled the same trailer manor 3023 with both a 99 Ford Ranger with the 4.0 V6 and then with a 98 Explorer with the 5.0 V8. With the 5 speed trans and 4:10 gearing the Ranger was a much better experience. Lots of things go into a good TV imo.
FWIW. That same trailer I pulled with the Ranger, I then put behind a 1 ton diesel. Guess what... they both did the job, held acceptable highway speeds and got us there.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2013 F350 CC LB 6.7
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
Anza-Borrego Desert SP area
Posted: 08/16/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
If you come to the Southwest it’s best to travel with water.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mrad
Prineton, MN
Posted: 08/16/21 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Grit Dog.
Back in 2004ish, we had 1994 suburban.It had 290 ft-lbs of torque. I don't remember the horsepower. we were looking for our first TT and found a 25' that was 4,800 dry and loaded was about 6,000lbs. That was about 400lbs over towing capacity. It towed without a problem on flat grounds. The only time we had an issue was in the black hills where we could only hit 30 mph on some of the inclines. With the extra gear or two you have, I don't see any problem towing that rig.
rexlion
Broken Arrow OK
Posted: 08/16/21 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
You should be okay, but you'll have to get used to the slower acceleration. Lock out overdrive to prevent transmission damage from heat buildup in the unlocked torque converter. You can downshift further on steep hills and let the engine rev higher to apply more torque; it's noisy but the engine is made to take it. Do pay attention to the hitch weight so you don't exceed the hitch's rating.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
RoyJ
Vancouver, BC
Posted: 08/17/21 02:34am Link  |  Quote  |  Print  |  Notify Moderator
Here's a trick to get better performance - put on the smallest tire with the highest payload that can match your factory rear GAWR. I believe it's 3400 lbs.
A 225/55R16 XL tire carries 1709 lbs @ 51 psi. 25.7" diameter. OEM is 29.5". It's a 15% gear upgrade at much lower cost.
If you have 3.55 gears, you now have 4.07. And 3.73 gears are now 4.28. It'll look funny, but the cheapest way to gain true towing performance. As a bonus your brakes will also feel much stronger.
2112
Posted: 08/17/21 02:47am Link  |  Quote  |  Print  |  Notify Moderator
What's your payload? Did they use the yellow sticker in 2004?
Our Explorer Sport had about 900lbs of payload.
2013 KZ Durango 2857
Posted: 08/17/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
My wife’s Equinox is 1085 pounds…and much smaller than an Explorer
