RV.Net Open Roads Forum: Do you believe this? 2022 Chevy 3500 HD dually
 > Do you believe this? 2022 Chevy 3500 HD dually
Wo.ody
East Coast
Posted: 08/16/21 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.chevrolet.com/trucks/silvera........+Payload&styleOne=421114&styleTwo=421114
Capabilities says Max payload 6838 lbs. WOW! Surely that's a mistake.
Supercharged111
Colorado Springs, CO
Posted: 08/16/21 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
So the curb weight of a brand new crew cab long bed diesel dually 4x4 is 7200#? I'll believe that when me shjt turns purple and smells like rainbow sherbet.
https://youtu.be/1xbLO5bB0Tk
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
specta
utah
Posted: 08/16/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
This 2021 GMC 3500 regular cab with the 6.6L gas has a payload rating of 7442 lbs.
If I were to buy a new truck today this is what I would buy.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
jimh406
Western MT
Posted: 08/16/21 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
If you do the math for a GVWR of 14K, the truck would have to weigh only 7172 which is probably than a SRW crewcab gasoline model with the smallest engine. Something is off.
Maybe regular cab with gasoline engine DRW with no fuel.
Kayteg1
California > Nevada
Posted: 08/16/21 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Did Chevy made what Ford did in 2017 and put aluminium beds?
The payload rating on heavy trucks was always taxable number and having no meaning in real hauling.
3 tons
NV.
Posted: 08/17/21 12:26am Link  |  Quote  |  Print  |  Notify Moderator
Eye Candy??
Geo*Boy
Unknown
Posted: 08/17/21 03:07am Link  |  Quote  |  Print  |  Notify Moderator
GM raised their GVW to 14,000 lbs. from 13,100.
JIMNLIN
Oklahoma
Posted: 08/17/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
GM 3500 drw also have a 10500 lb rawr for more load carrying capacity. 2020 GMs had the 14000 gvwr numbers so its not new.
GM has a good presence in the grocery getter/rv market. Their looking for more commercial vehicle sales from Ram/Ford one ton drw vehicles..... with those higher 10500 rawr numbers.
I've seen scale tickets on a couple of haulers webs showing 7200-7400 lbs rawr payloads on the '20 and up GM models. Those are WT models/2wd/dmax/std or double cab/long beds.
I just ran GMs weight calculator on a 3500 drw double cab/long bed/dmax/2wd LT. It shows a 7232 lb rear axle payload.
noteven
Turtle Island
Posted: 08/17/21 06:37am Link  |  Quote  |  Print  |  Notify Moderator
I have a Kenworth dually that fits in a parking stall with a 18,000lbs payload.
Why couldn't a GMC have 6838lbs ? (Not 6800 or 6900, but exactly 6838...)
54suds
adk mts.
Posted: 08/17/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
"I had one" traded as fast as I could for another double cab . In the standard cab they short changed quality on all sorts of things
2021 Chev 6.6 duramax ltz DBL cab,drw,4x/torklift tdn's,
1999 Bigfoot 1011
