RV.Net Open Roads Forum: Class A Motorhomes: Workhorse W24 (8.1L) fuel filter
 > Workhorse W24 (8.1L) fuel filter
init6
Near Fredericksburg, VA
Posted: 08/16/21 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
I saw a few posts about this subject but the links given in those older posts no longer work. My issue is this - I'm having a hard time finding the older 2005 Workhorse W24 chassis (gas 8.1L) fuel filters. Seems like they no longer make them. I'm even having a hard time finder the adapter so that I can use a more common filter that has 1 input and 1 output port (mind has 1 on the input and 2 on the output side). I'm guess that third connection is a return line. ANYWAY, I did come across this adapter and I'm wondering if anyone knows if this thing will work with the 2005 Pace Arrow - W24's.
Here is the link for it.
https://www.wheelerfleet.com/product/filter-kit-fuel/26878
If anyone has any experience with this I would love to hear about it. I believe if I had this adapter I could then use a newer 2 connection filter. As cheap as it is I would just buy the thing and try it but because my RV is 800 miles away in storage and when I go back to try to get this thing running correctly I will only have 1 day to do it otherwise I will have to leave it there again. So I need to show up with the right parts.
Thanks in advance
Picture of the filter type I need to match is here ->https://www.ultrarvproducts.com/image/cache//catalog/Products/Workhorse/Fuel%20Pumps/W8006889-location-800x800_0.jpg
* This post was edited 08/17/21 07:39am by init6 *
2005 Pace Arrow 37c
Workhorse W-24 Chassis
enblethen
Moses Lake, WA
Posted: 08/16/21 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Wix filter should be available at most O'Reilly auto parts.
Microgard O'reilly brand made by Wix
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
IB853347201
Eastern Ontario
Posted: 08/17/21 06:13am Link  |  Quote  |  Print  |  Notify Moderator
The fuel filter W8006889 at Wheeler fleet looks correct. it cross references to the Workhorseparts.com site. https://www.workhorseparts.com/index.php?route=product/search&search=W8006889&description=true
The original adapter that comes with the filter should still be in place on your Motorhome? you could just reuse it and buy just the filter?
https://www.ultrarvproducts.com/W0013351-Standard-In-Out-Fuel-Filter
2010 Suncruiser
init6
Posted: 08/17/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
OH.... I was under the impression the original filter didn't have an adapter but was actually a 1 piece design. I haven't gotten a close up look at it yet.
init6
Posted: 08/17/21 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately these filters won't work without that adapter to go from 3 connections down to 2. That is the part I can't seem to find anywhere.
RLS7201
Posted: 08/17/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Filter and adapter
Adapter part # WHG481FK
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Rick Jay
Greater Springfield area, MA
Posted: 08/17/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
(ON EDIT: You can probably skip this post and read my next one. [emoticon] )
Have you tried these folks: Luberfiner
Click on the W18/W20/W21/W22/W24 link and scroll down to the WHG481FK part link. I'm not sure if you can buy it from the website though. You might have to call. But if you type in your zip code, it'll show distributors nearby. Turns out, I have one in the next town over.
This company was mentioned from Oemy's Performance. Oemy's has been a long standing source of many Workhorse parts. Unfortunately, Oemy no longer makes his adapter, but does drop a name for Luberfiner above.
By the way, the original Workhorse/GM filter did have three ports on it. The adapter, which became available soon after someone figured out that the cheaper filter could be used if someone made an adapter, was available for purchase by Oemy by the time I needed my first fuel filter change. So I purchased it way back when (2005?), and I've been using it ever since.
Just make sure that IF you ever have someone else change the fuel filter to make sure they SAVE the adapter and use it on the cheaper fuel filter!!!!
Good Luck,
~Rick
* This post was edited 08/17/21 03:06pm by Rick Jay *
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (26-Angel since 2008), 1 girl (21), 2 boys (22 & 19).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
Rick Jay
Posted: 08/17/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
init6,
My apologies, I didn't follow your first link. THAT is the part you need. I just went to the link in your post and that seems to be to a company where you can buy it. I was able to put an adapter in my cart. I will say, from memory, that it is quite a bit cheaper than what they were going for back in the mid-2000's. You might want to purchase a spare, just in case someone accidentally throws away. Heck...I may order one...just in case. [emoticon]
I apologize for not following your link before I made the post above.
Good Luck,
~Rick
ON EDIT: I am going to order one for a spare, the shipping for under orders under $199 is $19.99. A bit steep, considering the size of the part. From what I remember, though, that plus the cost they're asking for the adapter is just about what they cost back in the mid-2000's.
On second Edit: OK...this post cost me about $150! LOL I HATE paying more for shipping than the cost of the part, so I added some filters and miscellaneous items to the cart to balance out the shipping charge somewhat. Weird, I know. Pay $150 instead of under $40. But that's how I roll! It's the principal of the thing! LOL
* This post was edited 08/18/21 05:06am by Rick Jay *
init6
Posted: 08/18/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
All good Rick. I went ahead and ordered one and I'll try my luck in October when I get back to the RV.
Cheers
Rick Jay wrote:
init6,
Good Luck,
~Rick
Rick Jay
Posted: 08/18/21 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
init6,
October should be about right. Here's the email I just received from their customer service:
"Good afternoon,
WHG481FK, filter kits are still on a national back order. Per the vendor, the delivery time has been pushed back to the end of October. We are trying to do our best to get these expedited for you. We apologize for the inconvenience but will continue to update you as we learn more.
Thank you"
I guess we just sit back and wait! LOL [emoticon]
~Rick
