Cummins12V98
on the road
SweetLou wrote: So what air filters do you run in your gas/Diesels besides K&N? Time to replace mine and looking toward Fleetgaurd but could o with the OE Mopar.
Lou, stick with MOPAR/FleetGuard. They filter VERY well and support your HP needs easily. K&N will "F" up your sensors, leave well enough alone!!!
Wrong spec but it is the CORRECT filter fo the 6.7. Used this one several times.
AMAZON
2007-2012 DODGE RAM 2500 3500 6.7L CUMMINS DIESEL AIR FILTER MOPAR OEM
Brand: Mopar
4.8 out of 5 stars 314 ratings | 8 answered questions
Amazon's
Choice
in Automotive Replacement Air Filters by Mopar
Price: $29.90
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
fj12ryder wrote: I pitched the K&N that was on mine when I bought it. IMO a diesel flows so much air the K&N needs to be thoroughly, and I do mean thoroughly, cleaned often. The one I pitched had crud deep down in the pleats. I replaced it with a Donaladson BHAF. This is on a 2001 Cummins.
You don't have what's known as a Modern Diesel and K&N is a BAD choice for the Modern rigs.
blt2ski
Kirkland, Wa
K&N is a bad choice be it gaz or deezal! As noted, it not bad at filtering. It's the oils that get on the sensors after it. Like you MAF, manifold pressure sensor etc. That's the issues you will have. Especially if you over oil the filter.
Better to use best quality paper AF you can get ahold of.
Marty
2014 Chevy 1500 Dual cab 4x4
FishOnOne
The Great State of Texas
Motorcraft(OEM) filters is all I use (air, oil, fuel filters) with 220k miles and my Powerstroke still hasn't been touched.
I remember watching a video were a mechanic was showing how a aftermarket air filter was dismantled because it couldn't handle the amount of air volume the Powerstroke pulls through it.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
1320Fastback
Vista, Ca
K&N is trash and will dust your motor.
Mine trucks old school and just run a 4" tube off the turbo to a dry MHAF.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
ktmrfs
Portland, Oregon
OEM delco for my duramax. mutiple tests show it is the best at filtering and while it has slightly more restriction than some others, not enough to make any difference in performance.
2011 Keystone Outback 295RE
ksss
Eastern Idaho
blt2ski wrote: K&N is a bad choice be it gaz or deezal! As noted, it not bad at filtering. It's the oils that get on the sensors after it. Like you MAF, manifold pressure sensor etc. That's the issues you will have. Especially if you over oil the filter.
Marty
True story, my MAF got oil on it and sent a code on my LB7 years ago.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
noteven
Turtle Island
to avoid fake parts from the interwebs I use filters bought in person:
Fleetguard filters for my Cummins'sz, in the latest supercession part number, from a Cummins Filtration dealer,
Toyota filters from the dealer for that pickup
Motorcraft filters from the dealer that pickup
Watch the you toob videos "Air Filters in the Nuclear Age" parts one and two
ShinerBock
LVTX
ksss wrote: blt2ski wrote: K&N is a bad choice be it gaz or deezal! As noted, it not bad at filtering. It's the oils that get on the sensors after it. Like you MAF, manifold pressure sensor etc. That's the issues you will have. Especially if you over oil the filter.
Marty
Most codes were not due to oil on the sensor. It was from the sensor being out of range. Most sensors back in those days were narrow band sensors meaning they only read a narrow range and anything out of that range(like more air) threw a code because it would mean that the truck had to guess on how much fuel to add. You do not have the same issue with todays wide band sensors that have much larger ranges.
If auto manufacturers were so worried about oil in MAF or MAP sensors, then they would not sometimes put them after the oil dump for the positive crank case ventilation or the EGR valve which introduces spend exhaust gas. I can guarantee that these two things would put these sensors through more oil and contamination than an oil bathed filter would.
This was my MAP sensor on my BMW diesel car. It was located in the intake after the EGR and oil dump, and all that black oily soot on my fingers came from the sensor. Nothing wrong with it. I just cleaned it and put it back.
last
edited 08/18/21 07:37am by ShinerBock *
View edit history
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
SweetLou
La Quinta, CA USA
No one here even mentions Wix. Why?
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
