RV.Net Open Roads Forum: Truck Campers: It's been fun
 > It's been fun
jimh425
Western MT
Posted: 08/17/21 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Congratulations on the next chapter.
As long as you put good tires on it, I think it will do ok in most weather that you should be traveling in. Sure, you might have chain up for best traction, but you also can wait that out.
Fwiw, we had no issues with our 32 ft Class A on a Feb ski trip to BC. I also knew a lot of people that regularly took theirs to the passes in WA for the weekend to ski. My older friends drove all over CA, NV in Winter in their 30 ft one. They are very heavy.
My suggestion is put some 3 Peak tires on it if you are at all worried about traction in Winter. A Banks Power pack if it doesn’t have one will help a bunch if it is gasoline.
Have fun.
thomas201
Eastern Panhandle WV
Posted: 08/18/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for a set of triple dual (or dual triple) chains. You can go anywhere, you should want to take such a rig. Practice putting them on and off in the driveway. Get chain pliers, hammer, 3 or 4 spare cross chains, with a hand full of cold shuts. All in the right sizes. Special note, they can tear up paved driveways.
mountainkowboy
Socal/NE Oregon
Posted: 08/22/21 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Made it home.......not bad, 7 mpg @ 24,500 scaled with the Ranger on a car trailer.
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
Camper_Jeff_&_Kelli
Seattle
Posted: 08/30/21 12:46am Link  |  Quote  |  Print  |  Notify Moderator
I too shall be joining the ranks of the retired in a month or so. I'm keeping the 4x4 F250 and 9.5 S&S. Aside from replacing the head gaskets 3 times before figuring out there was a machining error at the front right of the block causing water jacket failure within 3 months of replacement, a new starter, rebuilding the AC system, rebuilding the front steering, Rear Springs, Rancho 9000 shocks, 2 alternators, power steering pump, muffler which is needed again and finally a new engine, it's been a faithful truck. I won't bother mentioning the front right jack area frame rot fixed, or the rear right frame rot still to be fixed, and certainly not the Amish replacement fridge or the blown out cracked into 5 pieces escape hatch currently unable to locate parts so going to put a couple layers fiberglass over it. But I still love it... Hope to have paths cross sometime. Perhaps Arizona this winter... Best wishes to you...
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
burningman
Seattle, WA USA
Posted: 08/30/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Camper_Jeff_&_Kelli wrote:
the blown out cracked into 5 pieces escape hatch currently unable to locate parts so going to put a couple layers fiberglass over it..
Been there done exactly that. It works great, ends up stronger and more durable than a new plastic hatch cover.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Kayteg1
California > Nevada
Posted: 08/30/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
For escape hatch check Walmart.
The selection wary and right now I can only find complete assemble, but few years back they had cover only for $50, that fit my Lance
Walmart link
mountainkowboy
Socal/NE Oregon
Posted: 08/31/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
We will probably hit Quartzite this year again.
Camper_Jeff_&_Kelli
Seattle
Posted: 09/03/21 12:04am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at going. If the Truck Camper Meet and desert trail run is on this year, I'd like to hook up with them. Couldn't make it last year.
towpro
Compass PA
Posted: 09/03/21 06:03am Link  |  Quote  |  Print  |  Notify Moderator
almost looks like a camping site at the KOA in Outerbanks of NC. The fire rings really are almost that close, and guaranteed your neighbor will start a fire in it.
Enjoy the MH we did the same thing but stayed small.
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
mountainkowboy
Socal/NE Oregon
Posted: 09/03/21 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
HAHAHAHA, that pic is on the dealers lot, and that "fire ring" is a power outlet so they can plug RV's in. They always have 5 or 6 for sale.
This one is 30' I couldn't imagine going much smaller. Anything smaller we've seen lacks closet space, and it had REALLY LOW mileage.
 > It's been fun
