Charlie D.
E. Texas-Orange
We sold our 5th wheel and truck back last September because of health problems wife and I were having along with our Daschund becoming paralyzed. Our health is now better and we decided to buy a travel trailer.
I can kick myself for selling the the Duramax but that is in the past.
I have done the calculations and believe my numbers are correct but seeking confirmation.
Truck is a 2020 Silverado 1500 2 wheel drive LTZ. 5.3L with 3.23 axle. ITC, 8-speed with tow package and tow haul.
Scaled the truck weighs:
Steer axle-2880
Drive axle-2260
for a total of 5140
GVWR-6900
GAWR front-3700
GAWR-rear-3800
Conventional trailer-9800
Max tongue weight-980
Tires are 275/60R20 LT's
TT is a Grand Junction Transcend 240ML
UVW-6265
Hitch-598
Length-29'9"
I know this is close but will change with propane, hitch, battery, etc.
I will replace the Chinese tires with Goodyear Assurance.
Been to 3 dealers asking about WDH hitches. One recommends Blue Ox. Another Equalizer. Another a Fastway E2. Made in China so not an option.
Seems the Equalizer is highly respected and many people use them.
This being my first time pulling a travel trailer so what size weight distribution is your recommendation?
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
Terryallan
Foothills NC
Agree you are really close, and by the time you load it you will probably be over the max tongue weight, or right at it. You need from 10 to 12% tongue weight to make it tow correctly.
IF I were you, I would go with the Reese Dual Cam hitch. with no less than 800lb bars. It has built in sway control.
As for the tires. I have never heard of GY assurance trailer tires. Maybe you meant Endurance, which is a good choice.
enjoy above all else.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
amxpress
Clayton, NC
I had an Equal-i-zer hitch on my first TT.
Now I have a BlueOx Sway Pro hitch on my Airstream. It works well and does what it’s suppose to do, but it can be a ***** to hook up and to un hitch. It came with the trailer. Otherwise I would have gone with an Equal-i-zer.
2021 Toyota Tundra TRD Off Road double cab
2021 Airstream Bambi 22FB
Blue Ox Sway Pro hitch
Prodigy P2
Champion 3500 genny
M.I.L is self quatanting in Jacksonville Zoo
APT
SE Michigan
You'll be fine with that combo. Blue Ox SwayPro, Equalizer 4-pt, or Reese Strait Line/Dual Cam will all perform very well for you.
2017 Subaru Outback 3.6R
2020 Chevrolet Bolt
valhalla360
No paticular place.
You are going to be right at the limit for hitch weight (don't cheat and lower it).
The truck should do it but it won't be anything comparable to a big diesel.
WDH is more about proper set up than brand.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Near Bishop, California
My truck is similar. Your 3,23 read end concerns me. I’m fairly happy with my 3.42 with 5200 pounds of TT.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mkirsch
Rochester, NY
Lwiddis wrote: My truck is similar. Your 3,23 read end concerns me. I’m fairly happy with my 3.42 with 5200 pounds of TT.
He's got the 8 speed transmission. That's good for 2 rear end ratios so it will tow at least as well as a 3.73/4-speed, probably better.
The 1st gear is so low on those transmissions that it would be useless with much more than a 3.42. The engine will redline at about 2MPH.
blt2ski
Kirkland, Wa
I would get a Reese dual cam or equalizer wd/sway control system.
I've been pulling upwards of 8000 with no bars, with my 2014 new to me in late February with a V6, 6sp auto and 3.42 gears. The 8000 trailer was a literal small cement mixer with 1.5 yds of concrete in a rotating drum. I pulled a 3%grade in 4th, 1.05 direct equal at 55 doing 3500 rpm. You have another 50 ponies plus, along with at least 50 lb ft of torque than me. First gear is a 4.3 for you vs my 4.10 in trans. I believe gears 1-5 are closer spaced than my 1-4. Top three in both trans I believe are 1.05, .85 & .65.
I recently went to 285-65 tires vs stock 265-65-18 tires, gained 1" diam, reduced effective ratio from a 3.42 to about 3.23 like yours. I'm not going to say no difference. A lot may have to do with the tires being 10 lbs per heavier. I'm sure the effective ratio Change is part of the little slower to get going, lower mpgs.
I would not worry about pulling that trailer with your 1500. I'd pull it with mine.
Marty
2014 Chevy 1500 Dual cab 4x4
philh
Belleville MI
when it comes time to replace tires on TV, go with LT "E" tires. Huge improvement on tow experience.
blt2ski
Kirkland, Wa
philh wrote: when it comes time to replace tires on TV, go with LT "E" tires. Huge improvement on tow experience.
I put E tires after having D rated tires on a SW 3500. I ran the tires no higher in psi than the D's, typically 45-60 unladen vs loaded on the rear. 55-60 on the front due to the deezal engine. I noticed NO difference in handling etc with E rated tires.
My current 1500, input E's vs XL. Reality, worst performance, altho as noted above, taller, heavier, etc. Again, no difference handling with a 6500 lb trailer I've pulled multiple times. I don't need the tires at 80psi, as that's 16,000 lbs of tire gvw when I'm not over 8000 on the truck. 45-50 lbs is ample psi. So ANY lrC or XL rated tire is plenty of tire. OP will not have much, if at all over 4000 lbs. Stock tires are good to 2500 per side.
I had to go with LR E as that was only option with the 285-65-18 tires I wanted. IF an XL would have been offered, I would have bought them vs the LR E tires.
Marty
