Brought it home yesterday and a 30 mile trip from dealer.
Don't know pin weight but ordered a device that slips into truck receiver that has a gauge and gives you weight on ball
Certainly different from 3/4 ton Duramax. I believe hitch needs a little adjustment because there was a tiny bit of up and down on when moving. I will order Bilstein shocks to replace OEM.
RPM's is 2500 at 60 MPH. Equalizer 4-point hitch and I have always used 5th wheel hitches before so there is a learning curve.
Thanks for the comments.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
blt2ski wrote: I put E tires after having D rated tires on a SW 3500. I ran the tires no higher in psi than the D's, typically 45-60 unladen vs loaded on the rear. 55-60 on the front due to the deezal engine. I noticed NO difference in handling etc with E rated tires.
Marty
Correct. If you look at the inflation charts for D and E rated tires, you will see that they have the SAME weight ratings at various pressures.
The difference is the E rated tire can be aired up to 80PSI, allowing for more weight carrying capacity.
