RV.Net Open Roads Forum: Tow Vehicles: Stupid TPMS!!
Search only in Tow Vehicles
 > Stupid TPMS!!
Posted: 08/19/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
^My last Chevy 1500, 2016 model didn’t trip the TPMS at 32 psi or whatever this one is tripping at. I don’t recall getting a flat, but I know in the winter the rears were under 30psi sometimes with no issue.
Hell, I’m even getting used to the tire light as it’s a problem with most newer trucks. But the extra buttons to push at every startup to clear the “warnings” is really annoying.
2017 Heartland Torque T29
blt2ski
Kirkland, Wa
Posted: 08/19/21 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I'm driving a different frod transit than I normally drive. The light is on. Wondering if it goes on with too much air. Have 65 in the fronts, and normal is supposed to be 50. Rears are at normal 70.
I'm normally at 55 f, 65 rear for my typical loads etc. When I start hauling 3 pallets of antifreeze at 2100 per, I put rears at iirc max is 85 on the funky tiny 235-60-16 or some such size. About same diam as a 235-75-15. Don't haul 3000 per tire rating worth squat either.
Marty
2014 Chevy 1500 Dual cab 4x4
mkirsch
Rochester, NY
Posted: 08/19/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Why you running the tires so low in the first place? I run about 35-37 cold, get long life out of the tires, very even wear, better fuel economy, and great traction in the winter.
Also, no TPMS warning light.
Posted: 08/19/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I'll bump them up a bit to get rid of the warnings and idiot light, no problem there.
But I'm not running them "so low". At the 33-34 psi I set them at "cold" (on a 90deg afternoon when I rotated them) turned to 31 psi on the ensuing 60 deg mornings. More than enough air for a 285 wide tire on the back of an empty half ton truck.
It's just not enough for the General Motors legal team apparently!
blt2ski
Kirkland, Wa
Posted: 08/19/21 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
My 285's empty if I have more than 33-35 at any temp, the outside of the tread is not contacting the ground. I'm keeping them 30-32. Being as mine is older, I'm not setting a code on my 1500. Even as grit noted, when temp dropped a few times into the upper 50, low 60F I was seeing 27-29 on dash, and Guage.
Marty
Posted: 08/20/21 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Think the new 1500s trip the id10t light and danger warnings (lol) at 31 psi. Filled up up to 35 last night (on the TPMS reading) and lights went out.
This AM, they read 32psi on the tpms readout and no lights came on.
 > Stupid TPMS!!
