time2roll
If voltage is steady out of the generator... I will guess the converter is failing.
Does the voltage in the 12v panel rise and fall same as the battery voltage all in sync with the drop in amps?
675w Solar pictures back up
pianotuna
Regina, SK, Canada
test the generator by plugging in a 1500 watt heater. If there is no surging--then it may be the converter playing up.
edited 08/19/21 04:27pm by pianotuna *
Regards, Don
1L243
Oregon
I praised that wrong I turned off the inverter powering the trailer when on solar but left the solar and charge controller on.
The generator engine was running fine the surging had to do with electrical load
The amp surging would occur both on and off eco mode.
The amp surging was like a 30 second cycle.
My converter has four charging cycles as the charging on 75% battery level begins the converter could show 25+/- amps as the batteries become more charged it drops to 15a to 8amps and by the time ths batteries are at 90% to 3 amps or less. Which make charging on the generator for only 3 amps a waste of gas.
My batteries get down to 75/80% overnight.
This morning batteries down to 78% generator work fine no surging.
One interesting note although my batteries were at 78% my voltage level was at 12.1 MyChart says they should have been at 12.37 12.40?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
CA Traveler
The Western States
1L243 wrote: Which make charging on the generator for only 3 amps a waste of gas. Typical gen charging is 50-90% with solar to finish.
One interesting note although my batteries were at 78% my voltage level was at 12.1 MyChart says they should have been at 12.37 12.40? Typical chart voltage is for a battery at rest - ie NO loads for several hours. Draws reduce battery voltage and it will recover to its SOC at rest. Likely your battery was not at rest.
One main advantage of your battery monitor is the SOC reading.
2014 Grand Cherokee Overland
Bob
time2roll
1L243 wrote: The generator engine was running fine the surging had to do with electrical load So you found an intermittent load and all is actually fine?
time2roll
1L243 wrote: My converter has four charging cycles as the charging on 75% battery level begins the converter could show 25+/- amps as the batteries become more charged it drops to 15a to 8amps and by the time ths batteries are at 90% to 3 amps or less. Which make charging on the generator for only 3 amps a waste of gas. What converter? Once you hit peak voltage on the battery (14.4 volts?) run the generator one additional hour and you are done.
BFL13
Victoria, BC
If your monitor has the capacity too high and you use X ah in a day, then the batts will be down X ah and show the voltage for that, but the monitor will think they are higher in SOC than they are.
ISTR you are using your old battery bank this summer and one batt was worrisome, but you will get new batts this winter? You might be seeing what you would expect by now?
last
edited 08/19/21 04:58pm by BFL13 *
View edit history
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
DrewE
Vermont
Also, the voltage will be (somewhat) lower if the batteries are under load when you're checking the voltage. The chart values are for resting voltage usually. That said, my gut instinct is that 0.3V difference between resting and loaded voltage is fairly high for most circumstances where the battery bank is appropriately sized for the load.
MrWizard
Traveling
Most monitors do not compensate for Peurkert effect
Heavy loads such as inverter powered MW or coffee maker
Have a harder/stronger effect on battery capacity than the AmpHrs that are counted/measured by the monitor .
EXAMPLE
Use using 60 amps for 1 minutes, is not the same as using 1amp for 60 minutes, the monitor will count each event as 1 AmpHR, but the physical toll on the batteries is completely different, and with 60 amp load the batteries will have a lower voltage and less capacity than the 1amp load, even though the monitor will display the same SOC in each case
This could be your situation, according to battery voltage you were at 50% SOC, Not 78% indicated by AmpHR count,
3 amps or not, you need to get those batteries up to full, that means 14.4v and under 1 amp rate per 100AmpHR capacity,
0.5 amps per 100 at 14.4 volts is what I use to indicate full charge, the capacity count will indicate 100% before the batteries reach that charge rate, but I charge them until they reach that point, more batteries die from under charging sulphation buildup, than over charging, 400AmpHR bank, I charge until batteries take 2 amps or less at 14.4v
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
pianotuna
Regina, SK, Canada
Hi,
If I remember correctly, the Victron monitor does do a Peurkert calculation.
