RV.Net Open Roads Forum: Honda 2000i generator amps surging up and down
 > Honda 2000i generator amps surging up and down
bigfootford
Fair Oaks, California
Posted: 09/10/21 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
1L243,
DO NOT BUY WFCO
Ditto that!
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
bigfootford
Posted: 09/10/21 11:10pm Link  |  Quote  |  Print  |  Notify Moderator
You need to check the voltage at the converter or power distribution doing the same thing.
That is the only way to really know if the converter is doing it or it is a resetable breaker somewhere in the path to the batteries.
Jim
1L243
Oregon
Posted: 09/11/21 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Checked at power distribution panel and the voltage is going up and down a few 10ths of a volt as the converter cycles up and down. Plus the fan goes on and off as the cycle starts at high amps and then goes off as it gets to low amps. Over and over and over
I see Go Power makes a converter smart charger that will fit in the same place as the WFCO charger.
Any reocomendations?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
bigfootford
Posted: 09/11/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Well that pretty much confirms the issue.... Bad converter.
Many of us recommend the Progressive Dynamics series of converters.
If you have questions you can call them. Randy is the owner and he knows about installing and recommendations.
https://www.bestconverter.com/Progressive-Dynamics-Converters_c_81.html
Jim
Posted: 09/11/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
bigfootford wrote:
pianotuna wrote:
1L243,
DO NOT BUY WFCO
Ditto that!
Jim
Idk what this thread is even about, but can confirm the above
The wfco in our 2017 model camper is a glorious piece of ______.
2017 Heartland Torque T29
DrewE
Vermont
Posted: 09/11/21 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't be so quick to assume the converter is bad. Many converters will have their output voltage sag a little bit under heavy load; they aren't perfectly regulated voltage sources, as that's not in the least bit required for this application.
The real question is whether the load is cycling for some reason, causing the converter's output to also vary, or whether the load is constant but the converter's output is varying undesirably. Neither one has been proven at all conclusively, from what I've seen, but it kind of seems to me like a varying load and a reasonably functioning converter.
1L243
Oregon
Posted: 09/11/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
There is no load except for the charging it's self.
Im ready to throw a new converter at it just to see if it works.
* This post was edited 09/11/21 02:42pm by 1L243 *
deltabravo
Spokane, WA
Posted: 09/12/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
If I remember correctly, the Victron monitor does do a Peurkert calculation.
It does
1L243
Oregon
Posted: 09/12/21 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Interesting factoid. When I drew the batts down to 73% and plugged in the converter started to cycle. I left it unplugged and checked it again a few times and it still was cycling.
I decided to leave it plugged in for a while even though it is cycling it's still charging a little at a time. I checked it an hour later and the batts now up to 83% and the converter was charging as it should and no longer cycling.
Maybe it's when the converter is charging at it's highest rate of charge is when the problem occurs?
Regardless I think I will be going with the Progressive Dynamics 9260c.
Now I just have to figure where I'm going to get it.from.
bigfootford
Posted: 09/12/21 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Well now it just might be that the WFCO is thermalling out and shuts down the charge, cools off and starts charging again....
PROBLEM: Converter keeps shutting down.
SOLUTION: Ensure proper ventilation and check for obstructions regarding the cooling fan. WFCO converters are over temperature protected and will shut down.
FACT: Voltage will be present on both sides of the DC fuse terminals due to the LED circuit.
https://wfcoelectronics.com/common-power-products-misconceptions-issues/
I have had my 9260 PD... for over 10 years and it has had lots of use... I installed it into my Magnetic converter cabinet years ago. I only ran two FWC batteries and switched to 1 100ah Lifeline AGM a long time ago.
Jim
