RV.Net Open Roads Forum: Fifth-Wheels: 3rd AC
 > 3rd AC
Lou D
78577
Posted: 08/18/21 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2 month old 5th wheel. It has 2 AC's but in this South (and I do mean FAR South...literally will be in Pharr in a couple weeks currently in Houston)....these two just aren't cutting it. Am considering a 3rd AC be added. Considering ducted. However, can the existing ducts from what would be the middle AC to the rear living room be closed off some way, and the new 3rd AC be tied into those ducts (AC would be basically over the couch in rear of RV)?
CA Traveler
The Western States
Posted: 08/18/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
If the RV is not designed and set up for the 3rd AC including ducts and electrical then it could be a big job.
Is the RV 50A? Bigger ACs, window AC, mini split?
2014 Grand Cherokee Overland
Bob
Super_Dave
Harrisville, UT
Posted: 08/18/21 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same issue with 2 AC's not doing the job. I use a free standing fan in the living room and am thinking about trying one of the free standing AC units that I see advertised for around $450.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
TXiceman
Full Time RVer
Posted: 08/18/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Lou D, if not set up for a 3rd A/C, ducting and wiring will be an issue.
It would be great if you added a signature line to your post letting people know what kind of RV you have. Fill in any info you want to show and then scroll down to the bottom and click save.
Ken
Amateur Radio Operator.
jdc1
Rescue, Ca
Posted: 08/18/21 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Electrical supply would be your achilles heal. You would need to run another 20A supply form the 110V distribution panel to the AC.
wanderingaimlessly
Buggs Island lake
Posted: 08/18/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
You say new rv. Are you new to rving?
There are some things you can do that can help.
Are you in full sun? Even partial shade will make a difference, See if you can move to a shaded site.
Insulate your roof vents and skylights. Use of pillows for the 14 x 14 vent openings as well as the 14x22 in most showers help vent pillows
Situate your rv so the west side exposure is the passenger side so your awning will shade the side toward the sun in the afternoon.
These are quick items that may help, otherwise, do what rv'ers do. Go north and up in the summer months, go back to Texas in the winter.
wildtoad
Blythewood, SC
Posted: 08/19/21 05:03am Link  |  Quote  |  Print  |  Notify Moderator
If you’re parking in direct sun, even with three it may not be enough. Wanderingaimlessly has good advice. Also any windows that have direct sunlight should be covered with Reflectix insulating material. If added some to any cabinet attached to an outside wall.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Dick_B
Palos Heights, IL USA
Posted: 08/19/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Do you have Maxxair (or other) covers over the roof vents?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
alboy
Kelowna B.C.
Posted: 08/19/21 07:30am Link  |  Quote  |  Print  |  Notify Moderator
We have a portable 14000 inverter LG in our condo master bedroom ,280 sq ft.IT is very quiet and will freeze you out in a matter of minutes.IT would be a simple install and would be my choice at 650$. in Canada.
ON our 40 ft Landmark i played with the ducting to push more air to the Living area and closed the door to the upper level,stayed decent at 100 degrees
Super_Dave
Harrisville, UT
Posted: 08/19/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
So blocking some vents in the bedroom made the living space bearable?
 > 3rd AC
