RV.Net Open Roads Forum: Truck Campers: agm charging capability in 2016 Af 811SB?
 > agm charging capability in 2016 Af 811SB?
thealexdexter
Lake Stevens, WA
Posted: 08/18/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
My batteries are dead and I cant move the slide to check what charging system I have. I want to replace the lead acid with AGM but need to be sure I can charge them before buying. I almost positive this year/model uses a progressive dynamics PD9200 which can do AGM.
Can anyone confirm if this is the right charger in the 2016 AF 811SB and if that year also had the AGM charging capability?
https://www.progressivedyn.com/pd9200-converter/
THANKS!
2015 All Terrain GMC Sierra 4x4 CC Duramax
2016 Arctic Fox 811SB
Bedlam
PNW
Posted: 08/18/21 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
Run jumper cables between your truck and camper batteries to get the slide or jacks to move.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
ticki2
NH
Posted: 08/19/21 03:39am Link  |  Quote  |  Print  |  Notify Moderator
Even with no battery you should have power from converter if you plug into shore power
'68 Avion C-11
'02 GMC DRW D/A flatbed
Geo*Boy
Unknown
Posted: 08/19/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
My 2016 AF has AGM’s and charges just fine.
NamMedevac 70
Reno
Posted: 08/19/21 06:33am Link  |  Quote  |  Print  |  Notify Moderator
I have used an old exide small battery charger on lead acid and deep cycle bats with no problems. Had two settings for deep cycle, regular and two settings for 2 AMP and 10 AMP. Very small and handy. I still have it.
MORSNOW
Mountain Home, ID
Posted: 08/19/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
AGM is a lead acid battery so it will function exactly the same with your factory charger. AGM = Absorbent Glass Mat, so the acid is just held in basically a sponge versus being in a liquid state like a regular wet cell lead acid.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
thealexdexter
Lake Stevens, WA
Posted: 08/19/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all. I’m not near shore power and do not have access to jump from truck. It’s in storage. Sounds like I’ll be fine so I’ll buy the batteries and replace. Thanks.
