RV.Net Open Roads Forum: Tech Issues: 50 to 30 amp dog bone
 > 50 to 30 amp dog bone
Deano_1
New York
Posted: 08/18/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys,
Anyone use a 50mp to 30 amp dog bone for their RV? In some parks if there are many campers plugged into the 30amp service, would it be acceptable to use to dog bone with a camper with a 30 amp power? I heard of people doing this but just wondering how safe it is.
Thanks,
Deano
jdc1
Rescue, Ca
Posted: 08/18/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt it. The only issue would be your RV wiring being undersized. You could get overzelous and turn everything on, with all that extra amperage available, and overload that 10g wiring you have.
QCMan
Independent Republic of Horry
Posted: 08/18/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
With a dogbone you will be fine. Not so much with the puck type adapters. Lots of people use a 50 to 30 to get around the worn out and loose 30 amp sockets in a lot of pedestals. You will still be limited to 30 amps of usage but your connection will be solid.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
time2roll
Posted: 08/18/21 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
There is a 30 amp main breaker in your RV to limit you to 30 amps. If the cord shorts out by some improbable fluke the 50 amp breaker will open just fine.
675w Solar pictures back up
Roadpilot
NH and SWFL
Posted: 08/18/21 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
I use one all the time because the 50 plugs are usually in better shape than the well used 30 amp plugs. You can't overload anything by doing this. It's like to plugging a shaver into a 20 amp outlet.
Tiffin Wayfarer 25TW
15 Mini Cooper S
delwhjr
TX
Posted: 08/18/21 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
The typical 50 to 30 dog-bone only uses one of the hot wires available in the 50 supply. It will be perfectly fine. I have taken apart some which had been damaged to put on new ends. They were all wired this way.
2022 Rockwood 2109S
2006 Durango HEMI
Posted: 08/18/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
I carried a full set. Some parks there is an issue with the 30 amp outlets and the plug on some RV's (Seen it) so we hooked the RVer to the 50 amp outlet. via ye old bone. I've hooked 50 amp RV's into 30 amp sockets same way
Some folks yammer about how the 30 amp cord can't take 50 amps.
Well for hours on end yes. for the time it takes the 50 amp breaker to trip should somehthing short out.. No problem
Anza-Borrego Desert SP area
Posted: 08/18/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I always use the plug that looks the least used…usually the 50…when in a rare campground with electricity. I check polarity every time.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
BB_TX
McKinney, Texas
Posted: 08/18/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Simple answer. No problem using that adapter. Your 30 amp RV is protected by its internal 30 amp breaker.
Deano_1
New York
Posted: 08/18/21 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the responses. I will invest in one of these soon. One more question on this topic. I want to by a surge protection. Would I put a 30 amp protector “after “ the dog bone?
