RV.Net Open Roads Forum: Tech Issues: 50 to 30 amp dog bone
 > 50 to 30 amp dog bone
Bobbo
Wherever I park
Posted: 08/18/21 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Roadpilot wrote:
I use one all the time because the 50 plugs are usually in better shape than the well used 30 amp plugs. You can't overload anything by doing this. It's like to plugging a shaver into a 20 amp outlet.
This ^^^^^^^^^^^.
Bobbo and Lin
bob213
Fresno, CA
Posted: 08/18/21 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going to spend any money on a surge protector spend some more and get an EMS. That's true protection from more than just a surge. Progressive Industries, Hughes WatchDog, or Southwire are all rated well. Post, dogbone,(autoformer if you have one)EMS,RV is the order I do mine.
time2roll
Posted: 08/18/21 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Deano_1 wrote:
I want to by a surge protection. Would I put a 30 amp protector “after “ the dog bone?
YES
675w Solar pictures back up
Scottiemom
Posted: 08/19/21 05:32am Link  |  Quote  |  Print  |  Notify Moderator
At my house under my port, I only have a 50amp which was fine for the Phaeton. But the Phaeton is sold and I am using that same plug in on my B+ which is only 30 amp. I use a dog bone and it works fine. I do sometimes run the air, but still limit my total to under 30 amps.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
LouLawrence
Traveling the US!
Posted: 08/19/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
YES
Again, yes!
rhagfo
Portland, OR
Posted: 08/19/21 06:38am Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
YES
Rather than just surge suppression, get an EMS, this will run a check on the power from the pedestal before allowing it to be passed to your unit. Then it will constantly monitor it and shut down if it goes out of spec.
wapiticountry
Mountain West
Posted: 08/19/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
If your concern in voltage drop in the campground, switching to the 50 Amp connection will not change anything. Both the 30 and 50 amp connections run off the same service wires. There isn't a set of wires feeding the 30 amp connections and a separate set feeding the 50. What you might gain is a more solid breaker (the 50 isn't flipped off and on as much as the 30) and, as others have said, the fifty plug itself is generally not as worn as the 30. But then again, the 30 amp breakers and 30 amp plugs get changed more frequently during repairs and maintenance exactly for the reason they get more wear and tear, so you might find a 30 in new condition and the corresponding 50 worn.
phillyg
SWFL
Posted: 08/19/21 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Do it frequently, no problem.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
vermilye
Oswego, NY, USA
Posted: 08/19/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
While I only carry one 50 to 30 amp adapter, I know of individuals that carry 2, each with the 30 amp side wired to a different leg of the 50 amp side. They check to see which side provides higher voltage.
While both the 50 amp & 30 amp receptacles are connected to the same wiring to the pedestal, depending on how well the campground planed the balancing of the 30 amp receptacles throughout the park, one leg may well have a higher load lower voltage), particularly if there are mostly 30 amp users.
Jon Vermilye My Travel Blog
My Photo & RV link blog
