RV.Net Open Roads Forum: Travel Trailers: Almost lost the microwave while driving.
 > Almost lost the microwave while driving.
CavemanCharlie
Storden,MN
Posted: 08/20/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder if they just don't get their microwaves from the lowers bidder for that year (or few months) and the support boards were probably designed for the last batch of microwaves that came from a different bidder.
profdant139
Posted: 08/20/21 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I put plumber's pipe strap over my microwave to secure it within its cabinet. (The same stuff you'd use to protect a water heater from earthquake damage.)
It works. We tow over very rough forest roads, and the micro has never moved an inch.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Vinman02
Okotoks, Alberta
Posted: 08/20/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
I make sure the trailer tires are balanced, it helps keep things in their proper place.
2015 Ram 6.7 Cummins
2016 Arctic Fox 25Y
Honda EU3000i
Z-Peller
Oceanside BC
Posted: 08/25/21 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Easy fix I have done to 3 different rigs over the years that should have been done on installation. I screwed a 1/4” thick board on top of support boards with holes drilled thru in appropriate position and size for rubber feet on bottom of m/w to fit into. Then screw down a front to back board at each end of support boards and attach a poly strap side to side overtop the m/w and screw down to these boards.
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
Bobbo
Wherever I park
Posted: 08/25/21 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Nice. But first, you need to get the support boards UNDER the MW feet. That was my problem.
Bobbo and Lin
