RV.Net Open Roads Forum: Tow Vehicles: Auxiliary driving lights
Search only in Tow Vehicles
 > Auxiliary driving lights
monkey44
Cape Cod, MA and Central Fla
Posted: 08/19/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Monkey44: you may want to check and get your lights adjusted.
OP: I installed a pair of LED driving lights wire through a switch in the control circuit to a relay to act as daylight running lights. The switch is to turn them off when parking so as to not blind other campers. relay is wired to a good 12 volt hot location and the control is wired from a hot in run fuse location.
I aimed the lights slightly to the right so as to not blind on coming traffic. They are mounted lower then center line of headlights.
My lights are fine - it's the oncoming drivers that hit eyes high and bright. Manufacturers continue to brighten lights for safety, but eventually will brighten themselves right out of safe driving at night.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
enblethen
Moses Lake, WA
Posted: 08/19/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
I went back to delete the comment about your lights, but it didn't take deletion. You are correct about on coming lights!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cptqueeg
Idaho
Posted: 08/19/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
BMW has some pretty good tech to really take advantage of high powered headlights. Unfortunately, they ship them to the US w the systems inactive because it's not legal here.
PA12DRVR
Back in God's Country
Posted: 08/19/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
I'd go with floods for the other 2 for sure.
Pencil beams straight ahead, floods aimed out a bit.
The lightbar I have is spots in the center section and floods in outside lights. It lights up ditch to ditch quite well for a significant distance. Even with the truck having a great set of HID low beams (they're arguably brighter than the OE high beams both near and far), the spot flood LED lightbar combo is orders of magnitude brighter.
Also if everyone could leave the "You'll blind oncoming traffic and the law states you can only have 4 lights on" cr ap Karen arguments out of this thread, that'd be great, mmmmkay?
You don't know how I or anyone else drive or when an where we use our bright lights. Thanks!
Second the above.
The relevant wildlife where I'm at is moose...and I'm not sure any lights will dissuade a moose from crossing a nice hard-surface highway vs. snow...but floods on the outside of the vehicle/end of light bar/ etc seem to help a bit.
Having one's auxiliary lights on an auxiliary switch is a good thing.
CRL
My RV is a 1946 PA-12
Back in the GWN
LanceRKeys
Amarillo, TX
Posted: 08/19/21 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I would run spot and flood. I have my passenger side bulbs point slightly more to the shoulder to light up the ditch better and the driver’s side aiming straight ahead. When I installed mine I took my tools to a long flat stretch of two lane that is rarely used and set them that way.
Mine are wired so that they only come on when I have the dash switch on and when I have my high beams on, that way when someone comes over a hill or around a corner, I just turn my brights off, and my auxiliary lights turn off as well.
pitch
NY
Posted: 08/20/21 06:54am Link  |  Quote  |  Print  |  Notify Moderator
If you have even half a second advance warning of a critter, you are that far ahead. Go with the floods and have them aimed slightly towards the shoulders.
Posted: 08/20/21 10:15am Link  |  Quote  |  Print  |  Notify Moderator
PA12DRVR wrote:
Second the above.
I'm sure peoples perspectives are different in regions that don't have large critters, like, say the southern US for the most part.
And in my experience, lights don't dissuade any species of critter from jumping out in front of you.
But coon/possum/beaver = smashes the spoiler on your sports car.
Coyote = takes out a headlight or grille on your sports car.
Deer= likely a certain trip to the body shop. If you're in your sports car, might = a windshield replacement too. Talking little deer here, not big muleys.
Bear = hitting a brick with a low center of gravity
Elk = in your lap in anything shorter than a 4x4 pickup in a head on strike and like the bear, might total your whip.
Moose = may as well run into a tree or another truck, and unless you're sporting a 6" lift and at least 35s, Bullwinkle might also end up stuffed in the cab along with you.
I like my odds much better though when I can SEE them ahead of time!
2017 Heartland Torque T29
Posted: 08/21/21 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
So, did a little test last night.
The brodozer, aside from the lift, also has annoyingly bright HID low beams. And the light bar will fry your retinas! Lol
When we bought the truck, the PO had never adjusted the lights down due to the lift and being leveled. He said he’d just installed them and warned me I may want to swap them back for the OE lights because he was getting flashed all the time by oncoming drivers.
That was a very true statement!
I adjusted them down considerably. While still maintaining more than adequate sight distance. 99% stopped the oncoming driver flashes.
Last night driving home, noticed it seemed like the low beams projected further than the hi beams. And the hi beams are still OE stock conventional bulbs.
Hi beams made it brighter in the near ground than the low beams but again, didnt project as far.
Drive about 10 miles home, dark, 2 lane roads, good amount of oncoming traffic. ZERO hi beam flashes!
Point is, to the “new fangled” light haterz, it’s less about the lights and more about how you use them.
