RV.Net Open Roads Forum: General RVing Issues: Anyone Completely Redo Their Interior?
 > Anyone Completely Redo Their Interior?
AdvancedQs
Tampa
Posted: 08/19/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Looking at keeping my current RV rather than getting a new one, I have problems with:
1) Ceiling. Dopes put carpeting in up there. It’s really gross.
2) Cabinets. American style and dark coloring instead of Europe’s style cabinets, which I prefer. Need new cabinet faces and lighter simulated wood
3) Counter. Bad formica job where they left the brown edge. Looks dated and meh.
4) Decorative refrigerator panel. Gross dark brown to match the cabinets.
5) Floor. Old linoleum needs to be updated with something new.
6) Dinette. Would like to replace it with two small recliners and stick a small dishwasher between them to act as a table
7) Need to update the solar. Need more of it, different charge controller.
8) Carpeting around the floors. Old, stained, needs to be torn up and probably a different type of flooring put down.
9) New sink and stove/oven
10)) New truck or significant work needed on old truck.
11) new mattress
Is any of this worth it? Has anyone done a refit like this before? How many hours am I looking at?
There are vinyl trim pieces everywhere burying the roof carpet, walls, etc. looks difficult to replace properly.
I’m thinking it’s a $5000 project before getting the truck fixed or replacement. A lot cheaper than my other option which is buying a new truck and RV. I’m looking at $60-$70k for that and a bunch of work also. Would be doing a custom overland style in that case. This case is a truck camper redo.
How bad of an idea is this?
Tyler0215
Iowa
Posted: 08/19/21 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
If you enjoy the work, and have the time, go for it. It will be for your own gratification, you will never get the money back. Start at the top and work down and you can also repair any water damage on the way.
AdvancedQs
Tampa
Posted: 08/19/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
I actually don’t enjoy the work and would be just doing it as a means to an end.
I have been on another huge, marine related project for almost a decade and I can’t stand it anymore.
It’s a really, really small space here, but I don’t have the foggiest idea how long it might take to resurface all of this stuff.
IAMICHABOD
Sunny So Cal
Posted: 08/19/21 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like a lot of work,there is one thing that I may be able to help with.As for the ceiling it is best to clean it,I had the same problem on my old RV and removing and replacing was not a great idea,what a mess and then I had to redo it,managed to get it done after a few months and many failures.
As for cleaning on my newest RV with the same type of carpeting.
I have had great luck with Folex,on my ceilings just spray it on and BLOT don't rub,you will be amazed at how it lifts out the stains.
It may take more than one application but it took out all of my stains.
You can get it at most big box home improvement stores or Amazon check out the reviews and the pictures,I had the same results!
Former El Monte RV Rental
Buying A Rental Class C
Carlos & Ranae
Orlando, FL
Posted: 08/19/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
We took out all the carpets and replaced it with water proof laminate floor. We painted the bedroom, hallway, kitchen and living room and bathroom We also replaced the long sofa with a two seater and a table with 4 chairs
Carlos & Ranae
2017 Seismic 4212
2012 Dodge Ram, 3500 Laramie Longhorn
4X4, DWR, Pullrite 18KSuperslide Hitch
2006 Yamaha Midnight Silverado, 1700 CC
BobsYourUncle
Calgary Alberta Canada
Posted: 08/19/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have done all of that work you are describing, to a TT.
There is a certain logical sequence to do things in, based on the initial construction of the unit. They put them together in a certain order, and to redo something, you many times have to take a lot of stuff apart to properly access things.
I am putting up a website to assist people like you, but it is not quite ready to be launched. My site is nearly complete, but I have to proof read and test everything for mobile and desktop before I can launch it. Link in sig.
Do you have a place inside to do your work? I did my TT outside in my driveway. Wasn't very easy that's for sure.
Carpet on the ceiling - ugh! You'd have to peel it off and see whats under there to determine how to proceed. May have to remove the carpet, clean up the surface under it, then sand and paint.
If your cabinets are fastened from the inside only, it won't be too bad to redo them. It's harder when things are screwed in from the outside.
Counter isn't too bad, you can likely remove it with minimal effort.
Fridge panel is easy. Some minor disassembly and the panel comes out for replacement.
The floor needs to be one piece from front to back, side to side to do it right, but that involves taking a bunch of stuff out. The floor in my TT was replaced before I got it, and it is all curling up around everything because it isn't under the walls and cabinets. It looks terrible.
Dinette should be an easy one, most likely you can remove it from the inside.
Solar is easy, but you may need to fish wires to the roof.
Carpeting? Matter of opinion and taste. I hate carpet in an RV. It is a dirt magnet. I like all lino with small area carpets that can be removed for cleaning or easy replacement.
Sink, Stove and oven? Very easy to change out. It is one of the last things to go in, and it is fastened from the inside.
New truck? Buy two of them, I need one too! [emoticon][emoticon]
Mattress is an easy fix. Depends on the size too. Many are RV specific. Measure and compare. A standard size will be cheaper. I replaced one in my last TT - bought an off the shelf one for about 400 bucks. Perfect.
Can you elaborate on the vinyl trim pieces? Where are they and what do they cover?
It is not a bad or a good idea. It totally depends on your own situation. I agree putting 5K into an otherwise solid unit is better than forking out huge dollars for a new one. The new ones are not without problems either. Many of them are trouble from day 1. But some are really good too. Won't get into brand comparing here.
If your unit is sound and has no rot issues, I would say that doing some mods would be a good idea. But if you have rotten corners or soft floors, then do take a serious look at the overall picture. I can attest from personal experience that fixing up a rotten RV is not worth the work.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
PartyOf Five
Wheaton, IL
Posted: 08/20/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Solid advice from the previous poster, and I agree on the assessment. You do this for yourself and it's a labor of love not ROI. If you don't want it bad enough, then don't waste your time and just get something else instead - money is a lot easier to replace than time is.
PartyOf5 appreciating our Creator thru the creation. 5 yrs, 50k
May you find Peace in all you endeavor.
AdvancedQs
Tampa
Posted: 08/20/21 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Wow! That’s some excellent advice. Thank you, everyone. Especially BobsYourUncle.
The RV is a truck camper. Arctic Fox. It’s very solid. No leaks. I already own it. I was looking at changing RVs because I want something nicer inside and maybe a little more storage. I really don’t enjoy building things because I’ve done too much of that. However, any new options involve spending a lot of money I’d prefer to save and invest.
The one thing I am really uncertain about is how many hours this might take. The entire thing is only 18ft long and the non-bed part you can stand in is 9ft long. Tiny. But complicated.
A few more pics to describe the vinyl trim everywhere.
^this is the corner of a ceiling. Note the ceiling carpet, textured wallpaper and vinyl trim piece. This vinyl trim is everywhere.
^this is the floor. Stickers over 1/8” door skin like the cabinetry in this pic, lots of gross carpet and that brown vinyl piping.
^this is another corner of a ceiling near cabinetry. There is a brown vinyl piping any place there is cabinetry. Cabinetry is pressboard with a sticker on it to look like old style wood.
^this is the floor plan
* This post was edited 08/20/21 09:16am by AdvancedQs *
AdvancedQs
Tampa
Posted: 08/20/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Im not looking at this as any way to increase value. I just can’t look at this gross old style of interior anymore. I’m making a transition to using my RV a lot more and want something nice.
Any ideas on hours involved in this project? Including ceiling?
It just seems a shame to discard an otherwise perfectly functional truck camper when the interior styling is the issue.
I’m looking to get this kind of interior as far as styling goes:
Is it possible and any estimate on hours involved?
Or is it just better to spend $30k to get it?
Gdetrailer
PA
Posted: 08/20/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
"White washed" wood look?
UGG..
Not enough contrast for my taste with white washed cabinets and floors plus the white/grey backsplash and counter.
To redo the cabinets you would have to remove the existing finish to get to the bare wood on the doors/drawers and cabinet faces. If you are lucky, you have solid real wood and not laminated veneer or worse yet vinyl material. Once the finish has been removed then you can proceed with a white wash treatment.
New counter tops shouldn't be much of an issue, depending if you are planning to leave existing counter in place and cover with new laminate over top or planning to replace with Corian solid surface counters..
Flooring can simply be done with stick on imitation wood look vinyl planks in your color choice. Of course since all of the flooring was put down before the walls and cabinets were placed, you will have to cut around those to remove any carpet that is present.
Ceiling is going to present some challenged to replace, very good chance that every inch of it is securely glued to a backer board and that backer board most likely is glued and stapled in place..
I suspect you are going to kill quite a few hundred hours of time into it and a few thousand in money and good chance kill chances of selling it easily down the road (monochrome somber grey tones makes it feel "clinical" or hospital like).
