RV.Net Open Roads Forum: Truck Campers: Cracked rim on 2007 2500hd classic
 > Cracked rim on 2007 2500hd classic
Page of 6
deltabravo
Spokane, WA
Posted: 08/20/21 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
jimh425 wrote:
I’m guessing they are probably 1500 rims since that weight would be about right for a 1500.
Those are 8 lug wheels and were used on 1500HDs (a 1500 that had a GVWR of 8600 I think) and 2500 HDs. I have no idea if they were used on 2010 and older 3500s or not.
I would venture to guess that GM only made one version of that wheel, rather than a light duty version for the 1500HD and a heavier version for the 2500HD. THe problem of "two" weight ratings of the same wheel is that people wouldn't know they had different ratings and could mix them up.
2500HD GMT900 trucks had a rear axle rating of 6084 if I recall correctly. I had a 2002 2500HD with the same wheels. Those wheels were RPO code PYO.
I can't seem to find an official weight rating on a genuine PYO wheel, but it has to be higher than half the axle rating. I recall my rear tires were 3042 each for the weight rating.
OP:
Since your cracked wheel sports a low weight rating, I'd say it's an aftermarket look-alike PYO wheel and not one that came on a truck fro the factory, or from a GM dealer parts department.
deltabravo
Spokane, WA
Posted: 08/20/21 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Based on what I recall the PYO wheel's appearance being, your wheel is probably not OEM.
I recall OEM PYOs having marks on them, almost like machining marks, not a smooth polished appearance.
silverbullet555 wrote:
specta
utah
Posted: 08/20/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
JimK-NY wrote:
With a name and model number there should be a way to trace the specs.
Lead the way.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
Kayteg1
California > Nevada
Posted: 08/20/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Start with posting pictures of those numbers Specta.
Same goes to OP.
silverbullet555
Boise
Posted: 08/20/21 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
JimK-NY wrote:
If you have the name and model number you should be able to check the load rating. Don't assume they are suitable because they came off a 1 ton truck. The OP here also had them on an HD pickup.
Plenty of people buy wheels and tires they like without any regard to load ratings.
No! The OP here, me, had a wheel crack. The wheels on the truck are factory original the best of my knowledge. However, I DID buy an extra wheel that was supposed to be a factory GM wheel. It is entirely possible I was sold an inferior product and that is what is cracked. I'll find out this weekend when I pull another wheel off the truck and when I check my second set of wheels in storage.
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
specta
utah
Posted: 08/20/21 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
I hope the others are good so you only have to buy one replacement.
specta
utah
Posted: 08/20/21 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
Same goes to OP.
Why???
I know what I bought and what I am going to use them for.
I have zero concerns.
Kayteg1
California > Nevada
Posted: 08/20/21 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
so why are you here?
specta
utah
Posted: 08/20/21 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
I never asked a question.
I never asked what the weight rating was on my wheels.
I never questioned my choice and purchase.
Others did.
So why are you here??
What are you soo concerned with??
ticki2
NH
Posted: 08/21/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
An original OEM GM PYO aluminum wheel has everything printed under the center cap , no need to pull the wheel just remove the cap .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Page of 6
