RV.Net Open Roads Forum: Truck Campers: Cracked rim on 2007 2500hd classic
 > Cracked rim on 2007 2500hd classic
Page of 6
silverbullet555
Boise
Posted: 08/23/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Just to wrap this thread up.
I checked another wheel on the truck and it has the stampings on the front and the GM logo stamped on the wheel. I surmise that the wheel I was sold as an original was obviously not an original or GM OEM wheel. It was sold under false pretense and I didn't inspect it closely enough when purchased. Nothing I can do about it now.
We got INSANELY lucky that we didn't have a catastrophic failure at speed, either front or back. In this case this was on the back.
I share all this with the hope that people pay attention, don't make the same mistake I did and keep an eye on their trucks for signs of issues.
The upside is that I no longer feel the need to replace all my wheels.
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
Posted: 08/23/21 08:56am Link  |  Quote  |  Print  |  Notify Moderator
mkirsch wrote:
jimh425 wrote:
mkirsch wrote:
I thought rim ratings didn't matter, rims never break...
Naw, you seem to be confusing adding 200 lbs past a wheel rating with 1500 lbs.
Naw I'm talking about all the "advice" given in this forum to put LT E-rated truck tires on half ton rims and pumping them up to 80PSI on a rim rated for 44PSI.
There's no point to putting an LT tire on if you are not going to air it up. At "half ton" pressures (i.e. 44PSI and under) the tire has no more load carrying capacity than the stock P-metric tires.
Like the rest of the last couple pages of nonsense, I'd be super interested to see evidence of such a low pressure rating on "1/2 ton truck" rims. Same goes for light trailer wheels, 14 and 15 inchers.
2017 Heartland Torque T29
ticki2
NH
Posted: 08/23/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for getting back with the results . Good luck in the future .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Posted: 08/23/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
@silverbullet, yes thank you for following up and the confirmation that it was a cheap re-pop wheel , not OE.
jimh425
Western MT
Posted: 08/23/21 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I guess I missed “all” of those posts.
Posted: 08/23/21 10:10am Link  |  Quote  |  Print  |  Notify Moderator
You n me both, lol!
But what's really funny is (I quoted mkirsch's sig line) "Putting 10-ply tires on half ton trucks since aught-four."
Ole boy don't really know whether he's afoot or horseback....
Page of 6
