RV.Net Open Roads Forum: Tow Vehicles: New Chevy / GMC 3500HD options
Search only in Tow Vehicles
 > New Chevy / GMC 3500HD options
dhull
Some Lake Some where
Posted: 08/20/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
You'll probably want the snow plow package
wintersun
Monterey
Posted: 08/20/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
At the front wheels installing Rancho XL or other adjustable shocks will help to tune the suspension for any porpoising with the load on the rear axle. More load capacity at the front makes little sense as 85% or more of the weight of the 5th wheel will be supported by the rear wheels.
What can help with the ride is using a shock absorbing 5th wheel pin box like the ones from Trailair sold by etrailer and others. These will reduce road shock a great deal and also reduce chucking.
corvettekent
Marysville, WA
Posted: 08/20/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
corvettekent wrote:
The standard tailgate is powered and you can push a button inside the cab to raise or lower it.
You mean standard on High Country or other high trim levels, correct?
I'm not sure on all because I was only interested in the High Country.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Monterey, California
Posted: 08/20/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
I passed on the fancy, expensive tailgate. Looked to me to be an answer looking for a need.
deltabravo
Spokane, WA
Posted: 08/20/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
blt2ski wrote:
IF you get a DW ANY brand,
Correction: DRW (dual rear wheel, as in dually)
BenK
SF BayArea
Posted: 08/21/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
If me, I'd check how much that powered everything tailgate would cost to either repair or replace before ordering...
-Ben Picture of my rig
Posted: 08/21/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Ha, right!
Appears that’s not a concern for the OP though. Usually isn’t if one is buying a $80k truck.
But based on the guy on here recently that was like $3500 into a new Ford tailgate and all that had was a camera and lock (and maybe the pull out boat ladder thingy), I’ll go 5 large as a starting point for either the power gate or the Swiss army version.
2017 Heartland Torque T29
FishOnOne
The Great State of Texas
Posted: 08/21/21 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Pass on the Chevy and get the much better looking GMC is the only option I would consider.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
on the road
Posted: 08/22/21 07:36am Link  |  Quote  |  Print  |  Notify Moderator
I am confused. You ordered a new truck and you are asking questions after the fact????????
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
4x4ord
Alberta
Posted: 08/22/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
When you select the diesel engine the front springs will automatically be selected to carry the extra weight of the engine. Heavier front springs would be for those using their truck for a camper or snow plow.
2021 F350 SRW Platinum short box 4x4.
B&W Companion
