RV.Net Open Roads Forum: Class A Motorhomes: old diesel fuel in tank
 > old diesel fuel in tank
Page of 5
schmitts711
Michigan
Posted: 08/21/21 06:26am Link  |  Quote  |  Print  |  Notify Moderator
KD4UPL wrote:
Some of the fuel in my generator tank is about 4 years old. Some of it is older than that. I put some kind of biocide in there maybe 3 years ago. It runs the generator just fine.
I started up the generator and it ran okay for a minute, then it started surging, so I turned it off. Is this what would happen if I had bad fuel?
schmitts711
Michigan
Posted: 08/21/21 06:32am Link  |  Quote  |  Print  |  Notify Moderator
wolfe10 wrote:
Biocide is something like Biobar JF.
I was looking for biocides on Amazon and saw this. Sounded like what I wanted. I was going to add a shock dose (1 ounce for 40 gallons), let it sit for a week or so, then run the rig and generator. If everything is okay, I'd try to do a trip where I can burn off the old gas. Should I try to burn off most of the half tank before topping off?
Matt_Colie
Southeast Michigan
Posted: 08/21/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
If you have to hit the fuel with a biocide, be very ready to replace both fuel filters and learn how to bleed a dry fuel system.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
mowermech
Billings, MT
Posted: 08/21/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Algae, I have read, only grows when water is in the tank. It grows at the water/fuel interface.
No water in tank, no need for biocide. Water in tank, the tank should be drained and cleaned, then filled with fuel, and all fuel filters replaced.
Diesel fuel does not rot and turn to varnish the way gasoline or gasohol does. Age does not mean much to diesel fuel.
CM1, USN (RET)
Daily Driver: '14 Subaru Outback
Toad: '05 Wrangler Unlimited
Toy: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
wolfe10
Posted: 08/21/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Correct.
But (OK large BUT) the original post said the tank was stored HALF FULL for two years. Very likely there has been enough condensation to provide the water necessary for microbe growth.
Storing with a full tank reduces condensation.
* This post was edited 08/21/21 10:27am by wolfe10 *
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
rgatijnet1
Posted: 08/21/21 10:16am Link  |  Quote  |  Print  |  Notify Moderator
The moisture/condensation in the tank could also have caused the exposed metal surfaces to rust which may start to show up in your fuel filter as rust colored debris. It will quickly disappear as the fuel flushes it away.
stickdog
Somewhere, USA
Posted: 08/21/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Carry a spare fuel filter.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Mel Stuplich
Wausau, WI
Posted: 08/21/21 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
schmitts711,
Google "diesel fuel polishing near me".
FUEL POLISHING is a FUEL CLEANING PROCESS that filters diesel fuel in fuel tanks to remove contaminants... (Also known as diesel fuel polishing or diesel cleaning services), fuel filtering effectively removes water, microbial particles, and sludge from on-road and off-road diesel.
schmitts711
Michigan
Posted: 08/21/21 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Already have that on order and will carry it with me just in case. Still wondering what the advice is on when to top off the tank. Should I do it ASAP before trying to use up the old 40 gallons? Either way, prior to storage for Winter I plan on having the fuel filter replaced.
schmitts711
Michigan
Posted: 08/21/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Correct.
On the upside being in Michigan the rig is in storage during the cold months of November-April, which should help inhibit growth. I've had the rig since '17 and in all honesty have never added a biocide and never had an issue. The difference this time is COVID kept us from traveling in '20 which ended up doubling the time it sat untreated.
Page of 5
