RV.Net Open Roads Forum: Class A Motorhomes: old diesel fuel in tank
 > old diesel fuel in tank
Page of 5
PastorCharlie
NC
Posted: 08/22/21 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Yes, fuel polishing (common on diesel boats because of the same storage issue) is an alternative.
That will remove water, microbes, dirt etc.
That is what the fuel filters and water separator is for. You have the systems already installed on the vehicle.
schmitts711
Michigan
Posted: 08/22/21 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what a mobile fuel polishing service would cost, but I'd have to compare that to the cost and trouble of replacing my fuel filters a couple times. Might it not be easier and cheaper to have the fuel polishing done (if I can locate a mobile service)?
dieseltruckdriver
Black Hills of SD
Posted: 08/22/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
schmitts711 wrote:
dieseltruckdriver wrote:
As it has been said, if it smells ok, just top it off and then drive it off, or at least as much as you can.
I would highly advise having spare filters.
I'm not sure I could tell you what good diesel smells like. Maybe I'll have someone more knowledgeable take a sniff. But you think I should get some fresh diesel in it right away?
Not necessarily right away, just before you use it. Fuel lasts much longer than gasoline, so it wouldn't concern me. My advice for the biocide was a CYA thing, as it is possible for some growth and it will plug your filters if you have it, but again, you may not.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
schmitts711
Michigan
Posted: 08/24/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
It will not "cure" diesel that has "turned". Smell fresh diesel, then smell from your fuel fill. We are not talking about a subtle difference!
Yes, we FEEL you will be fine. But would sure hate for our long-distance opinion to lead you into an expensive repair.
Got a chance to sniff my tank today, and it smelled like fuel to me. I didn't pick up any hints of algae or decay.
schmitts711
Michigan
Posted: 08/28/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
I think and pray you're right pastor. Can't get out until early October, but hope my filters do the job they were intended for. Taking spares just in case.
schmitts711
Michigan
Posted: 10/08/21 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Just wanted everyone to know that I took the Journey out yesterday and everything was fine. I wanted to burn off as much of the old fuel as I could so I drove out a rural expressway for an hour and then an hour back, running my AC and generator the whole way. When I got back home I was down to a quarter tank. I filled up with fresh diesel and a 'shock dose' of Biobar. The Lord was good to me. So were the other posters here and I thank you all for taking the time to give me advice. I learned a lot about diesel along the way.
Posted: 10/08/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Baring algae diesel lasts a long time
The one that amazed me was a gasser.. Sat for years... Fired up and ran like new after we put a new chassis battery in it.
Bruce Brown
Northern NY
Posted: 10/08/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Good to hear.
We just returned from a 2,200+ mile trip, topped off 2 miles from the house and put it away for the season. Unless something changes it won't come out of the garage for around 7 months. I have zero concern about the diesel going bad.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
schmitts711
Michigan
Posted: 10/09/21 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Bruce Brown wrote:
Good to hear.
I've owned our Journey since '17 and never even heard of problems with water or algae after storage. But the pandemic set us back a year and the rig ended up sitting for 2 years with only half a tank. I looked into possible issues with the fuel when I fired up the generator and it started surging. That's when I investigated and found out that... oops!, should have put an additive in. Apparently Cummins builds their machines to withstand owner neglect. I'm thankful!
schmitts711
Michigan
Posted: 10/09/21 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I think what saved me was the long period of time that temperatures don't rise to a level that will support algae growth in our northern latitude. Plus my storage site isn't exposed to a lot of intense Sun. I couldn't even find a mobile fuel cleaning service. Not sure if the same applies with storing gassers... but at least there's an apparent advantage to a cold climate with diesel!
Page of 5
