RV.Net Open Roads Forum: Bubbles on the side of his RV
 > Bubbles on the side of his RV
newownerneedadvice
Washington
Posted: 08/20/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Any one knows a quick fix for a Bubbles for side wall so I can just sell the thingAny advice would be very much helpful I just don’t wanna put any more money into this if I don’t have toTimes are tough but I bought this I am invested it was a bad investment because I listen to somebody else so I’m just trying to make it livable for me and my son thanks guys
MountainAir05
New Mexico
Posted: 08/20/21 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
There is none.
jdc1
Rescue, Ca
Posted: 08/20/21 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Park next to a tree, houase or block wall. Drill 1/4" hole through the filon (not the plywood). Spray some minimal expanding foam in the hole. Cover the affected area with plywood. Place a few 1X2 braces from the plywood to the wall, wedging it so the filon flattens out. Remove the wood the next day. Caulk the hole.
wolfe10
Posted: 08/20/21 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I would use a good two part epoxy as the "adhesive", not foam.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
way2roll
Wilmington NC
Posted: 08/21/21 06:06am Link  |  Quote  |  Print  |  Notify Moderator
You said you wanted to sell it and then said make it live-able. Which is it?
rgatijnet1
Posted: 08/21/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
The bubbles he is talking about MAY be in an RV with aluminum side walls in which case they will be paint bubbles that must be removed, filled, and repainted. Most of these bubbles include corrosion through the aluminum skin, water behind the skin, and the repair can get pretty involved.
way2roll
Wilmington NC
Posted: 08/21/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
From another post it's a 96 coachman. That wouldn't have aluminum sidewalls. I assume it's delamination. No real good fix for that. Aside from the sidewall, it's likely there is water damage in the wall as well.
William Willard
Brookins Oregon
Posted: 08/21/21 07:35am Link  |  Quote  |  Print  |  Notify Moderator
No fix for delamination -- Water leak is the cause -- There`s a luan backing for the fiberglass siding --Water causes the luan to seperate & it will not hold any kind of adhesive -- If you try any of them,you`re probably gonna create more problems than you have now --
bgum
South Louisiana
Posted: 08/21/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Put a for sale sign on it. Take the first offer you receive.
Monterey, California
Posted: 08/21/21 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Trouble and difficult to fix on newer RVs. Sell, take a loss on this “investment” and buy another RV after a complete inspection.
