newownerneedadvice
Washington
Any one knows a quick fix for a Bubbles for side wall so I can just sell the thingAny advice would be very much helpful I just don’t wanna put any more money into this if I don’t have toTimes are tough but I bought this I am invested it was a bad investment because I listen to somebody else so I’m just trying to make it livable for me and my son thanks guys
MountainAir05
New Mexico
There is none.
jdc1
Rescue, Ca
Park next to a tree, houase or block wall. Drill 1/4" hole through the filon (not the plywood). Spray some minimal expanding foam in the hole. Cover the affected area with plywood. Place a few 1X2 braces from the plywood to the wall, wedging it so the filon flattens out. Remove the wood the next day. Caulk the hole.
wolfe10
I would use a good two part epoxy as the "adhesive", not foam.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
way2roll
Wilmington NC
You said you wanted to sell it and then said make it live-able. Which is it?
rgatijnet1
The bubbles he is talking about MAY be in an RV with aluminum side walls in which case they will be paint bubbles that must be removed, filled, and repainted. Most of these bubbles include corrosion through the aluminum skin, water behind the skin, and the repair can get pretty involved.
way2roll
Wilmington NC
rgatijnet1 wrote: The bubbles he is talking about MAY be in an RV with aluminum side walls in which case they will be paint bubbles that must be removed, filled, and repainted. Most of these bubbles include corrosion through the aluminum skin, water behind the skin, and the repair can get pretty involved.
From another post it's a 96 coachman. That wouldn't have aluminum sidewalls. I assume it's delamination. No real good fix for that. Aside from the sidewall, it's likely there is water damage in the wall as well.
William Willard
Brookins Oregon
No fix for delamination -- Water leak is the cause -- There`s a luan backing for the fiberglass siding --Water causes the luan to seperate & it will not hold any kind of adhesive -- If you try any of them,you`re probably gonna create more problems than you have now --
bgum
South Louisiana
Put a for sale sign on it. Take the first offer you receive.
Near Bishop, California
Trouble and difficult to fix on newer RVs. Sell, take a loss on this “investment” and buy another RV after a complete inspection.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
