valhalla360
No paticular place.
jdc1 wrote: Park next to a tree, houase or block wall. Drill 1/4" hole through the filon (not the plywood). Spray some minimal expanding foam in the hole. Cover the affected area with plywood. Place a few 1X2 braces from the plywood to the wall, wedging it so the filon flattens out. Remove the wood the next day. Caulk the hole.
Ummm...expanding foam is likely to lift an even larger section as it expands with no place to go.
As others have said, there is no good solution.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
wgriswold
Lake Tahoe
wolfe10 wrote: I would use a good two part epoxy as the "adhesive", not foam.
There is a material called Git Rot that boaters use to repair water damage. I would try that in place of foam.
You also need to find the water leak that caused the damage.
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
oldave
Tx
Read this thread
https://www.monacoers.org/topic/2899-epoxy-oh-no/#comments
Ray
Gjac
Milford, CT
If you can describe in more detail where the bubbles are and how big an area the cover and post some photos you may get better answers as to how to fix it.
MountainAir05
New Mexico
Thank you very much for the link. You did a great job that most people would not have went to to repair this. My uncle was a boat builder and I have seen him drill holes and plate both sides and inject resin back into the damage spot.
Gene
bob b
Grants Pass, Or
I got an estimate ten years ago to repair a similar condition and was surprised to find out the expense. I was quoted $1,000 a foot. I sold it and moved on. Bob
bob b
oldave
Tx
Gene
Gene, it wasn't me doing the repair. It was another member of Monacoers.
Ray
way2roll
Wilmington NC
Seems like the OP never returns to threads so it's hard to know if any of this helped.
2023 FR Sunseeker 2400B MBS
oldave
Tx
way2roll wrote: Seems like the OP never returns to threads so it's hard to know if any of this helped.
Happens all the time
4x4van
California
Without pictures of exactly what the OP is talking about, everything offered here is just WAG's.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
