RV.Net Open Roads Forum: Tech Issues: 50 amp TT with generator
 > 50 amp TT with generator
Pammuela
Manteca
Posted: 08/21/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
We just purchased a TT (2021 Jayfeather 27BHB). It is a 50 amp trailer and we have a Westinghouse I4500 generator. Based on the output of the generator it should run our AC, (13500 BTU) but the generator only has a 30amp plug and we have an adapter. I have 2 questions - 1) should we be using an EMS with the generator and 2) is our generator big enough to run our AC?
Thanks in advance for your help!
pianotuna
Regina, SK, Canada
Posted: 08/21/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
no need for ems
yes it should run the air.
Regards, Don
Monterey, California
Posted: 08/21/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I have a Westinghouse generator. Well made, lasts if you regularly service it. Enjoy your new TT. Consider reading the basics on RV electricity.
stickdog
Somewhere, USA
Posted: 08/21/21 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Quite possible your EMS would not allow your genny to power your trailer.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
bob213
Fresno, CA
Posted: 08/21/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
If your EMS shows an open ground just use a neutral bonding plug which you can make yourself.
time2roll
Posted: 08/21/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
1) NO
2) YES
675w Solar pictures back up
valhalla360
No paticular place.
Posted: 08/21/21 11:59am Link  |  Quote  |  Print  |  Notify Moderator
If it's a single air/con unit, yes. If it's multiple air/con units...maybe, maybe not.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
theoldwizard1
SE MI
Posted: 08/21/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Probably with a MicroAir Easy Start on both !
valhalla360
No paticular place.
Posted: 08/22/21 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
With soft start and also check how things are wired up, it's possible. Usually, 2 air/con units are on separate legs of the 240v, so you need to get power to both legs without creating a conflict between the 2 hots.
Posted: 08/22/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on yoru generator it may be possible to run TWO Air conditioners but since I do not know the genny... I can not be sure.
