RV.Net Open Roads Forum: Tech Issues: 50 amp TT with generator
 > 50 amp TT with generator
DrewE
Vermont
Posted: 08/22/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
Usually, 2 air/con units are on separate legs of the 240v, so you need to get power to both legs without creating a conflict between the 2 hots.
The standard 30A to 50A plug adapters will do just that.
I'm not sure what you mean by "creating a conflict between the two hots"; on most RVs, they are pretty practically independent of each other, only sharing the same neutral return (and, of course, safety ground). If you have any 240V circuits--which are not too commonly found in RVs--then they just won't have power when connected to the 120V supply since both legs are at the same potential all the time.
Bobbo
Wherever I park
Posted: 08/22/21 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
What he means is that the 2 air conditioners are on separate legs of the 50 amp system. Or should be. A 30 to 50 dog bone adapter puts them on the same (30 amp) leg. That is "creating a conflict between the two hots" since both A/C units may try to start up at the same time.
Bobbo and Lin
