RV.Net Open Roads Forum: Help, 2003 Arctic Fox fridge isn’t staying cool when on DC
 > Help, 2003 Arctic Fox fridge isn’t staying cool when on DC
pianotuna
Regina, SK, Canada
Posted: 08/21/21 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
riah wrote:
OK, thanks every one for your replies!
The biggest issue is voltage drop.
My 3 way fridge works GREAT on 12 volts--so long as I'm plugged into shore power. On batteries only--even though I have 556 amp-hours and 256 watts of solar it doesn't work well at all.
If you want to "fix" the problem, then add a dc to DC charger and set the voltage at 14.8.
Regards, Don
Buzzcut1
Norcal
Posted: 08/21/21 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
for about $500 you can upgrade the Cooling unit to one of the Amish Built ones. My old cooling unit failed and I installed a new Amish one about 2 weeks ago. So far the performance of the new unit is substantially better on AC, DC and Propane. At 100F outside the Fridge stayed at 35 and the Freezer kept the Ice Cream frozen solid. I had it on DC while driving and Propane while dry camping
https://rvcoolingunit.com/Norcold-Cooling-Units-remanufactured-C4434.aspx
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Posted: 08/22/21 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for sharing that.
2017 Heartland Torque T29
