RV.Net Open Roads Forum: Towing: Big Tires pulling Small tires.
Search only in Towing
Open Roads Forum  >  Towing
 > Big Tires pulling Small tires.
NRALIFR
Truck Camping Out West
Posted: 08/22/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
SweetLou wrote:
So the tire spins 1.3 times faster but we really don't know the speed of those small tires? Can we say 1.3 times faster than the truck, or 78 mph?
No, you can’t.
That would be nothing more than a variation of the trick question: “Which weighs more, a pound of feathers, or a pound of lead?”
The tires spin at a higher RPM, but the MPH is the exact same as the truck pulling it. [emoticon]
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
theoldwizard1
SE MI
Posted: 08/22/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Bottom line. Re-pack those bearings regularly !
JRscooby
Indepmo
NRALIFR wrote:
No, you can’t.
A track loader is moving 8 MPH. How fast is the pad on the ground moving?
valhalla360
No paticular place.
Posted: 08/23/21 05:29am Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
CA speed limit is 55 mph for all vehicles towing.
So it's perfectly safe to run 70mph in Nevada but cross the state line and suddenly, it's dangerous? This is a political rule that has nothing to do with the tire speed rating.
Pull the model and look up the speed rating.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
SweetLou
La Quinta, CA USA
Posted: 08/23/21 07:00am Link  |  Quote  |  Print  |  Notify Moderator
There is always someone in the bunch. They write more tickets.
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
SweetLou
La Quinta, CA USA
Posted: 08/23/21 07:01am Link  |  Quote  |  Print  |  Notify Moderator
NRALIFR wrote:
No, you can’t.
Ya dun caught me
SweetLou
La Quinta, CA USA
Posted: 08/23/21 07:05am Link  |  Quote  |  Print  |  Notify Moderator
This is exactly what I told him. Also told him to do it himself. I pulled recently cargo trailer wheels that had been done last summer by a place I know that I thought did good work. I was amazed at what they considered packed. Do them yourself save and know.
Posted: 08/23/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
SweetLou wrote:
Actually his old trailer is an old U-haul but he says it doesn't say that 45 mph rule anywhere. The tires on it are new and for a car since he really doesn't weigh it down any. The tire brand and specs say 937 lbs at max pressure which I don't know what that is. So the tire spins 1.3 times faster but we really don't know the speed of those small tires? Can we say 1.3 times faster than the truck, or 78 mph?
Yes, exactly.
Except the trailer is still going the same speed, but comparing the rpms of the wheel, to something everyone can grasp (mph) is accurate.
Like mooky said, them 10" snomachine/pontoon boat trailer wheels hold up reasonably well at higher highway speeds, although not near as well as larger diameter tires.
PS, the 45mph uhaul max was/is to keep people who don't tow much, driving slower, IE less accidents and liability. Nothing to do with the trailer being able to not go faster without coming apart.
2017 Heartland Torque T29
Posted: 08/23/21 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Significance or relevance?
blt2ski
Kirkland, Wa
Posted: 08/23/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Probably neither. No different than here I Wa st where rigs under 10k g w or no towing can go 70 where marked. Towing or licensed over 10k gvw you can only go 60mph max anywhere. That include licensed rig empty under 10 k, but licensed over 10k.
Marty
Check RV.Net Blogs at: blog.rv.net
