Ziphead2
Newark
I have a 2017 Minnie Winnie and am having trouble with my black tank draining. I dont know if the issue is the gate valve outside that is stuck or what. I let it sit until; next stop about 150 miles. I thought whatever is stuck would work its way out. Before we left i put some chemicals down to include Happy Camper but still no go. I am thinking the gate valve is broken closed? If not I'll have to work my way from the valve to the tank. Any opinions? I am open to any ideas/as always thanks!
jdc1
Rescue, Ca
Open the toilet and look inside. Is there any water? Add water and drive around, to mix it all up real good. If that doesn't work, it's gonna get real messy. Run something semi flexible up the waste connection. Better have a few huge buckets on hand, or be right next to a cleanout.
valhalla360
No paticular place.
What are you basing the issue on:
- If it's the pretty lights on the monitor, they always show up as full even after you drained.
- Do you hear anything when you open the valve?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
LouLawrence
Traveling the US!
Tank Flush
You can buy an adapter like this and hook up a hose. It water goes into the tank you are OK. If the water just flushes back out the valve is broken and stuck closed.
richclover
NV
LouLawrence wrote: Tank Flush
Get the model with the gate valve.
Rich
2018 Ram 4X4 2500HD Cummins
2020 Chaparral 336TSIK
2019 RAM 1500 Classic 4X4 Hemi
2021 CanAm Maverick DS Turbo
Southern NV
falconbrother
North Carolina
Go to Walmart and buy the reverse flush thing. It works good. If that doesn't work...oh dear...
ACZL
UPstate,NY
OS !
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
You pulled gate valve “open”, nothing came out?
99.9% sounds like broken gate valve to me.
Start there.
2017 Heartland Torque T29
Terryallan
Foothills NC
The flush attachment at wallyworld works really good, and is reasonably priced. About $15.00. It also directs the stream straight back into the sewer pipe. Shoots about 25 feet.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Dusty R
Charlotte Michigan 48813
Look from under neath to see if the slide valve/gate is opening.
