RV.Net Open Roads Forum: Toy Haulers: Placement of motorcycle for towing
Search only in Toy Haulers
 > Placement of motorcycle for towing
pjs1660
ohio
Posted: 08/22/21 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
I'm getting my first toy hauler soon. Where is the best place to strap a bike weighing between 800 and 1200 pounds ? Behind the axle, closer to the ramp, or over the axles? Thanks
arhayes
Posted: 08/22/21 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
Have to assume you’re getting a towable and not a 5ver. I’d assume their tie downs are placed for optimal loading.I’d think it’d be set up more over the axles. On my 5ver, I keep it in the center of the garage and the weight is behind the axles. However, pin weight is essentially the same whether the bike is loaded or not.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
4x4ord
Alberta
Posted: 08/23/21 04:02am Link  |  Quote  |  Print  |  Notify Moderator
There usually isn’t going to be a whole lot of options. If you are happy with your tongue/pin weight directly over the axle is best. If you’re needing to add pin weight move the bike as far forward as possible …. move it back to reduce pin weight. My bike and carrier weighs about 1000 lbs and is about 17 feet behind the centre of the tandem axles. That is about the worst place to carry that much weight but it works. My rv handles noticeably better without the bike.
* This post was edited 08/23/21 04:08am by 4x4ord *
2021 F350 SRW Platinum short box 4x4.
B&W Companion
Y-Guy
Tri-Cities, WA
Posted: 08/23/21 04:16am Link  |  Quote  |  Print  |  Notify Moderator
pjs1660 what type of toy hauler are you looking at? Bumper pull or 5th Wheel? Any idea of length yet? For the vast majority of Toy Hauler owners there is very little impact on the tongue weight of the larger haulers, but it does vary so knowing what you are looking at helps.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
valhalla360
No paticular place.
Posted: 08/23/21 05:48am Link  |  Quote  |  Print  |  Notify Moderator
Generally, the garage is already in place, so you don't really have a choice.
Yes, 1200lb can significantly impact the hitch weight. The further behind the axles, the more it impacts. They usually design toy haulers with higher hitch weights, so when it loses weight due to loading, it's still got a decent percentage on the hitch.
Also, a big 5th wheel is less impacted than a smaller travel trailer. A big 15,000lb 5th wheel, likely starts around 3000-3500lb hitch weight and the axles are set further back, so if a 1200lb bike takes 400lb, off the hitch, it's still got 2600-3100lb (17-21%) on the hitch. That's the lower end of acceptable but still OK. A 6000lb bumper pull is likely starting around 700-900lb hitch weight, so if you lose 400lb, it's down around 300-500lb (5-8%) on the hitch. That's in the range where stability becomes an issue while towing.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
lincster
Mesa Az
Posted: 08/23/21 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Pin weight, or tongue weight, won't change that much with just a motorcycle, independent of placement.
I've done all of the weight measurements and vehicle placement.
The biggest item to change pin/tongue weight is water or no water.
My sand rail is 3000lbs and the pin weight in my 5er is still 3600lbs with the motor/trans hanging 5' behind the rear axle.
My water tanks are 80% in front of my front axle and I always tow with full water.
2019 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Posted: 08/23/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Agree, unless it is a very small toyhauler, it likely won’t make a huge difference, except toyhaulers are generally tongue heavy without a load in the garage, so you may find loading it as far rearward as possible will do the most to combat excessive tongue weight.
2017 Heartland Torque T29
noteven
Turtle Island
Posted: 08/23/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
That 1200lbs … is it just the one motorcycle or two of them?
Dirtclods
Newport Beach
Posted: 08/23/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
The best place is - over the axles.
pjs1660
ohio
Posted: 08/24/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
https://www.rvtrader.com/listing/2021-Forest-River-CHEROKEE-WOLF-PACK-24PACK14%2B-5017338133
