RV.Net Open Roads Forum: Travel Trailers: Fresh water tank
Page of 5
vtraudt
Brighton, MI
Posted: 08/23/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Bobbo wrote:
The pump, showing hose connections (both male),
That is what I could envision also. Male/Male (garden hose adapter from pump ???? thread to garden hose male thread) on pump.
Discharge (fill hose) existing fresh water garden hose.
Short suction (garden-) hose to stick into tote?
Bobbo
Wherever I park
Posted: 08/23/21 10:50am Link  |  Quote  |  Print  |  Notify Moderator
The water bladder, when empty, takes up FAR less space than any tote. Lighter too. You see it folded up under the pump in the "kit" photo. As well as filling the fresh water tank in a single trip to the faucet.
Bobbo and Lin
TUCQUALA
Kennewick, WA
Posted: 08/23/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
get a "turkey oil pump" to use in your water jug. Only 15-20 $$ and uses D batteries, pumps fairly quickly. Easy to store!!
https://www.amazon.com/CHARD-FOP-23-Draining-Outdoor-Fryers/dp/B00HCC2L6A/ref=sr_1_2?dchild=1&keywords=deep+fryer+oil+pump&qid=1629739434&sr=8-2
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
vtraudt
Brighton, MI
How do you drag a full bladder from well to camp site?
That is where 'tote' (=wheels) come into play.
Question is if/how to make suitable connection from pump to tote using external (self suck) pump.
Will test 'throw in' fountain (submersible) pump this week. May run a while (no real rush), but very simple/cheap.
ktmrfs
Portland, Oregon
Posted: 08/23/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
vtraudt wrote:
ktmrfs wrote:
we dry camp a lot and often need more water. Solution:
1) install a second water pump in the pass through plumbed to the fresh water inlet with a long extension and dip tube on the inlet side and a power switch
Not clear about 'pass through plumbed to fresh water inlet': where is this 'pass through' running to/from? Where do I find it?
Or are you saying tap (T or Y) into the filler line and run a 2nd pump, discharge INTO the filler line and run long suction hose from the 2nd pump out/down to reach the 7 gal?
to clarify. yes, the output of the second water pump is T'd into the fresh water fill pipe and yes then a long suction hose attached to a stainless steel "dip tube" that I stick in the vent side of the blue fresh water tank.
If you don't want to or can't T into the fresh water inlet, you can run the pump outlet through a flexible outlet hose and stuff it into the fresh water inlet of the trailer as well.
2011 Keystone Outback 295RE
ktmrfs
Portland, Oregon
Posted: 08/23/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Bobbo wrote:
My boondocking water kit. Throw the tote in the truck and go. Has everything except the hoses, that live in the TT anyway. The blue thing is the 45 gallon potable water bladder.
The pump, showing hose connections (both male), switch, and fuse. I have an SAE connector on there because I have an SAE supply on the trailer, and battery cables with an SAE connector. I can power the pump either way.
Neither large, nor heavy. To me, at least
the 45 gallon bladder is certainly a good solution if it's easy to fill at the campground, less space and easier to do than jugs, but Many campgrounds we go to the fresh water source (a) isn't really accesible with a truck with a bladder in it, and (b) no threads on the water spigot so you need a "water thief" and a LONG hose. So that' why we use the 7 gallon jugs.
vtraudt
Brighton, MI
Posted: 08/23/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs wrote:
Next time I check the plumbing (primary pump, fill line, etc), I will determine if
a) fix install 2nd pump with plumbed tie in, electrical switch, somehow make 'suction' hose connection (plumbed; protection connector for long removable (so it can be stored clean) suction hose to tote
b) all portable solution (pump wired with electrical quick connect to 'port' on trailer; garden hose connectors on pump; suction hose to tote (stick in or threaded), 'fill' hose into fresh water fill.
Posted: 08/23/21 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Never seems to gather any traction or commentary, but a wakeboat ballast bag and pump is a literally plug n play option with a 12V cig plug and a long extension cord on the pump.
Can get bags or package deals with pumps in many different sizes and shapes of bags. Alot of times can get a good price on a package deal on a generic size bag and pump combo that aren't the latest and greatest.
* This post was edited 08/23/21 12:40pm by Grit dog *
2017 Heartland Torque T29
rlw999
Washington State
Posted: 08/23/21 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
A full 45 gallon bladder would weigh 375 lbs, I'm not sure that there are any wheels are going to help with that unless you've got a paved surface with no inclines - it's almost certainly going to sit in the back of the tow vehicle.
Even the pictured 10 gallon wheeled tote is going to weigh over 80 lbs, so it's going to be hard to move it very far by hand unless you're on flat pavement.
vtraudt
Brighton, MI
Posted: 08/23/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
10 gal is easy to roll (yes, certainly flat, gravel/paved).
Bladder in car to get water is not a desired option for ME, rather go twice with 7 gal jug (mine has wheels, works well) or the 10 gal 'tote' on wheels (strap to back of trailer or under floor for storage).
Page of 5
