RV.Net Open Roads Forum: In Need of a 2013 Ram 3500 Switch Bank Wiring Harness
Search only in Tow Vehicles
 > In Need of a 2013 Ram 3500 Switch Bank Wiring Harness
SweetLou
La Quinta, CA USA
Posted: 08/23/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have been having issues with the Switch bank which controls the Tow Haul, Exhaust brake, park Sensor which is all located below the Uconnect. Sometimes it works, other times nothing, or 30 min down the road it works. The dealer a couple months ago replaced the switch bank and everything worked. Now it works as I mentioned and the diagnosis is a short in the wiring harness. Problem now is that the harness has been discontinued. I really don't understand that when the truck is only 8 years old but what do I know. And with what did they replace it with if anything. Can someone direct me to help find this part or recommend something else?
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
enblethen
Moses Lake, WA
Posted: 08/23/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have the part number for the harness?
Try Dave Smith
* This post was edited 08/23/21 12:46pm by enblethen *
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
SweetLou
La Quinta, CA USA
Posted: 08/23/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Try Dave Smith
I don't. The Truck is at the dealer in Spokane so not to far but I would think they would reach out to Dave Smith.
Posted: 08/23/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I'm of no help, but, man, what a terrible turn of events.
Having been on (too many) forums for these trucks, cannot say I've heard of that issue until now. Best of luck getting it repaired!
But, are you saying that whole switch bank was intermittent or not operable at all prior to the first replacement of the switch bank and then it worked 100% of the time for a couple months and is now intermittent again?
If so, that seems to me to be either the new switch bank or possibly a bad connection. If the new switch fixed the same condition previously.
2017 Heartland Torque T29
Posted: 08/23/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
Those switch panels are quite inexpensive both new and used (<$100) and plug and play I believe. I'd be thinking about replacing that again personally before going down the wiring harness rabbit hole.
Just a thought.
Plus if you had a dealer do the prior replacement, is it under warranty?
And how did they diagnose the wiring harness, just by default since the switches are new?
enblethen
Moses Lake, WA
Posted: 08/23/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Shame you do not have part number. You could check with Spaldings
I doubt whether your dealer will check with Dave Smith!
IdaD
Idaho
Posted: 08/23/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
You're out of warranty, get it to a good diesel shop and to heck with the dealer service department.
2015 Cummins Ram 4wd CC/SB
Posted: 08/23/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I'd also ask your question on Cumminsforum or one of the others.
Huge knowledge base and you have a seemingly needle in the haystack type issue.
Good luck!
SweetLou
La Quinta, CA USA
Posted: 08/24/21 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Name one because I really don't know of any around Spokane. PM me
wing_zealot
East of the Mississippi
Posted: 08/24/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
How about a wiring harness from a truck in a junk yard?
