RV.Net Open Roads Forum: Technology Corner: WiFi Camera always late to the action
 > WiFi Camera always late to the action
sch911
Rochester Hills, MI
Posted: 08/23/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Nest are the gold standard but expensive. Look at "WYZE" as a cheap alternative.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Ranger Smith
Wherever the rig is parked
Posted: 08/23/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
monkey44 wrote:
As you all know, M44 is not very technical minded. But, to me, it would make sense to install in instant capture camera that can record to a flash card then send to a SSD or a phone a delayed WIFI signal - like a time-lag. Then you would have instant record, miss nothing, and still have the WIFI signal send it to a more secure device elsewhere or direct to your phone.
That might take a minute or to before WIFI kicks in, but not enough time for a 'bad guy' to find and destroy a recording before it sent the signal out.
Maybe I'm missing something? Probably [emoticon]
I do know even ten years ago, we could shoot and record action images on the baseball field - and manually upload and send to our editors via WIFI right in the camera ... it took a few minutes, but that's it - the editor would have the image almost immediately after the shot.
I can imagine that technology is quite a bit advanced nowadays. And motion activated - instant on - record - send, and I'd imagine instant record should be available in a fixed security camera even if it waits a few seconds to actually connect to the WIFI service and send video.
The Wyze camera's do that. They have a built in slot for a micro SD card.
Where we are now
Amateur Radio Operator WW1SS . . . Yaesu FTDX101D, Ameritron AL-80 Amp, Icom 7100, Yaesu FT-991A
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
monkey44
Cape Cod, MA and Central Fla
Posted: 08/23/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah - I figured it would be available as much security minded all of us are today, especially in the more populated areas.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
fj12ryder
Platte City, MO
Posted: 08/23/21 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Our neighbor has the Wyze cameras around his house and he loves them. He says there is an available feature that allows you to program what will set off the camera. He set his so the dog doesn't constantly set it off. I'm considering one or two to put around the pool area, for when we're away from home.
Howard and Peggy
"Don't Panic"
bgum
South Louisiana
Posted: 08/24/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Does Wyze only show 12 seconds of recording?
Corkey05
Washington State
Posted: 08/24/21 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the responses
It looks like I'll look into the Wyze system for some relief. I'm not totally dissatisfied with my Arlo system, but my issue is talked about a lot on the Arlo bulletin boards. I have one camera pointed at my front porch, by the time a delivery person enters the range, drops a box and leaves he has managed to do that in maybe 1-3 seconds, the time it takes for the camera to connect to the base station (Hub) and internet. What I get is a nice video of the front porch, but nothing else. But is does record spiders on the lens flawlessly.
BTW, the Arlo hub is plugged directly into the router, so this issue is owned exclusively by Arlo and its hub. The hub is still wifi, but nothing I can do to improve a closed system.
This issue goes far beyond simply improving the internet situation. My front porch camera is less than 20 ft from the router and my MBPS is 385. The connection just couldn't be much better. I have other internet devices over 150 feet way (even outdoor sheds) working without issues, it's a fairly robust system. As a security device the cameras performance should be much better. According to the Arlo community boards I'm certainly not alone.
Thanks again, you folks did help!
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
srt20
Wisconsin
Posted: 08/24/21 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
We use Blink, an amazon owned deal I think. Works well, micro SD slot for storage. Sends alert to phone, etc. Cheap. 3 cameras and module for well under $200 ( I dont recall exact price, amazon stuff is on sale every other day).
We live in sticks and have slow internet at home (20mbps is max). Im happy with the Blink setup. Of course Amazon would prefer you buy the storage plan from them through their cloud, but I prefer using my own card.
APT
SE Michigan
Posted: 08/25/21 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I have several Wyze V2 and V3 cameras. The motion detection is a little sensitive, but otherwise meets your requests listed so far. Person/vehicle detection costs extra. Cameras cost about $35 ea, power via Miro-USB, and connect to the internet via Wifi.
I am shifting my own home to Ubiquiti Protect product with better control of cameras, detections, and local storage with no service/subscription fees, but the equipment costs are noticeably higher.
2017 Subaru Outback 3.6R
deltabravo
Spokane, WA
Posted: 08/28/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Why is the camera "disconnecting" from the network? Once you set up a WiFI device, it should always stay connected.
Corkey05
Washington State
Posted: 08/28/21 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Deltabravo ... what you say sounds good on the surface, but to leave several cameras connected full time hogs valuable wifi device connections. Each wifi router has connection limits. So they only connect after motion is detected and that might take 3-4 seconds, enough lost time for the object in motion to move outside the field of view. Hardwired systems can stay connected full time, just like you say, but WiFi has limits. It's not unusual to have 40 (or more) WiFi devices fighting for connections all the time. I would love to have a full time Hub to record action full time, then spool to the WiFi when connected or convenient.
