RV.Net Open Roads Forum: Class A Motorhomes: 22.5 wheels
 > 22.5 wheels
brianseay1
Bridgeport, Ala USA
Posted: 08/23/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
this may be a stupid question but i'm gonna ask it anyway. Can you run a steel wheel on the rear inside and a Alcoa aluminum wheel on the outside without any issues. I'm thinking it should be no issue, but just want to get some valuable info from you all. I want to buy 4 Alcoa wheels to put on my coach and I plan on running two steel wheels on the inside of rear axle. Thanks for any info.
Brian & Neena & B.G.
B.G. 2014 Goldendoodle
2007 Coachmen Cross Country 389DS
300 HP Cummins Turbo Charged
03 Sahara Jeep Wrangler & 05 Harley Davidson Ultra Classic
2014 800 RZR4
Roll Tide Roll
Ranger Smith
Wherever the rig is parked
Posted: 08/23/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
I do believe I had a motorhome set up like that. Also I think my 2012 Ram Dually had the Alcoa's or similar on the outside and the inners were steel. The people you are purchasing the rims from should be able to tell you for sure though.
You have a doodle too . . . We have 2 of them Tuxedo Doodles brother and sister
Where we are now
Amateur Radio Operator WW1SS . . . Yaesu FTDX101D, Ameritron AL-80 Amp, Icom 7100, Yaesu FT-991A
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
wolfe10
Posted: 08/23/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, there were some OE coaches fit that way. Saved the manufacturers a few $$.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
dodge guy
Bartlett IL
Posted: 08/23/21 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
That’s how all the F53’s come. My 12 is like that and my buddys 17 is the same way.
They are coated but I would use anti seize where the wheel goes around the hub, dissimilar metals.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
ferndaleflyer
everywhere
Posted: 08/23/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
My last 2 DPs were that way as is my F-350. I don't think I ever saw an Alcoa on the inside
lryrob9301
Mid-Atlantic
Posted: 08/23/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Most all motorhomes with Alcoa wheel options are built that way. Also the front wheels are a different offset than the rear wheels.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
diplomatdon
Blaine, WA
Posted: 08/23/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you can run steel inners and aluminum outers. Deal with a tire shop that does trucks and they will use a teflon ring between the wheels to prevent electrolisis between steel and aluminum.
JRscooby
Indepmo
Posted: 08/24/21 04:20am Link  |  Quote  |  Print  |  Notify Moderator
Many trucks are sold with steel on the inside. In years past there was a disc between to reduce corrosion where the dis-similar metals meet.
Something to look at is the studs. Will they be long enough to get a full nut with the thicker wheels?
William B
On the road
Posted: 08/24/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
It's how our coach is set up.
Full timing since 2004
2007 Holiday Rambler Navigator 45' DD Series 60
2019 Dodge Ram 1500 Limited
Our Blog
Hikerdogs
Wisconsin
Posted: 08/28/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
You might need new longer studs on the rear drums or rotors. Aluminum wheels are much thicker than steel ones.
Hikerdogs
2013 Winnebago Adventurer
 > 22.5 wheels
