RV.Net Open Roads Forum: Travel Trailers: 6 Volt Battery Winter Maintenance Advice?
 > 6 Volt Battery Winter Maintenance Advice?
pbohart
Portland, Oregon
Posted: 08/23/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hi -
I have had a couple sets of 2 x 6Volt Trojan T125 batteries on my RV over the last decade. I have previously dropped them into my RV then forgotten all about them - including when I drop my RV off on Mount Hood for the winter when the temperatures drop below freezing fairly regularly. Needless to say, I am sure I am not getting full lifespan/value from my purchase.
I just bought a new set which I intend to only use only for regular camping in Spring/Summary/Fall. I will keep the older set for Winter use as I have full hookups where I drop my RV.
Question - Is there a good summary of how to maintain the new set during the Winter? I assume I will be removing them and keeping them on a 6V trickle charger? Any suggestions on a trickle charger that gets the TT forum seal of approval?
Thanks!
2010 Chevrolet Silverado 2500HD Diesel
2012 Jayco Eagle Super-Light 314BDS
CA Traveler
The Western States
Posted: 08/23/21 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Options:
1. Fully charge the batteries, remove the cables and you will have self discharge of about 4%/month, good for about 6 months.
2. Charge them at home with a battery maintainer.
3. Charge them at home about once a month.
2014 Grand Cherokee Overland
Bob
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 08/23/21 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure they're full of water
Charge them
Disconnect the cables
It work fine for me down to -60F.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
pbohart
Portland, Oregon
Posted: 08/23/21 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
Awesome advice! Thanks!!
Is there a 6V battery maintainer that either of you (or others) would recommend?
FLY 4 FUN
Alberta
Posted: 08/23/21 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
Big fan of the Deltran battery tender chargers. You can decide what model suits your needs and budget.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
pianotuna
Regina, SK, Canada
Posted: 08/23/21 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
charge them and disconnect.
Regards, Don
StirCrazy
Kamloops, BC, Canada
Posted: 08/24/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
theres another option. if you hve a good converter in the rv and you leave it pluged in, just leave the batteries set up as normal. I got 14 years out of my lst 6V batteries and they only time they wernt plugged in was when I was driving or camping with out services.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Sandia Man
Rio Rancho, NM
Posted: 08/24/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
I do nothing different for our Samsclub purchased 6 volt golfcart batteries during the winter months as opposed to summer. Regardless of the time of year we keep our batteries properly watered and always plugged in letting our smart converter or inverter charger keep them happily charged.
We experience at least 4 months yearly of sub-freezing temps and easily get a minimum of 8 years of reliable service, they always have life still left in them but with the sales they occasionally have at Samsclub on GC2 batteries we tend to get a fresh pair.
For less than what we spend on fuel for a single RV outing we have 12 volt reserves for many years to come, don't see myself going with newer battery technologies any time soon as we have always had good success over several decades of RVing.
Thermoguy
Graham, WA
Posted: 08/24/21 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I remove mine and store them in the garage for the winter. I connect the 6V together to make a 12v. I only have a 12v battery maintainer so just connect like I do in the trailer.
Would be interested to hear if this is not the correct approach. Do I need a 6V maintainer?
Boon Docker
Posted: 08/24/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Yes, you are doing it right with 12 volts. You do not need to use a 6 volt maintainer.
