RV.Net Open Roads Forum: Tech Issues: Battery box vent size?
 > Battery box vent size?
S Davis
Western WA
Posted: 08/24/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
I am installing an inverter system on my truck, it has two separate battery boxes that will hold three Lifeline GPL-30HT each for a total of six, one box will vent to the other and then that box vents to the outside of the cab, What size vent should I run?
enblethen
Moses Lake, WA
Posted: 08/24/21 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Here is an example of what you need.battery vent kit
AGM batteries are normally sealed and do not require venting.
I would use two separate venting system and not connect together for vented lead acid batteries.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
