RV.Net Open Roads Forum: Tech Issues: Fan Speed Control
 > Fan Speed Control
Page of 5
Posted: 08/26/21 04:28am Link  |  Quote  |  Print  |  Notify Moderator
There are two ways to control the fan speed on a DC fan
One is to use a resistor. this has been the way it has been done traditionally since at least the 1950's or before. (I only go back to the 50s)
The other is a "Buck" converter. These are DC-DC converters. they swap amps and volts just like a transformer.. I've never tried them but ALL ELECTRONICS dot com has a selection of them at a decent price. What size fuse is in the fan? Get one at lest that many amps.
ajriding
st clair
Posted: 08/26/21 10:03am Link  |  Quote  |  Print  |  Notify Moderator
2112 wrote:
What happens when battery power is too low to move the fan and the PWM is sending out power still? Harm to fan? Harm to controller?
That could be a problem. A quality controller would use a low voltage dropout regulator to protect itself from this. The one you pointed to can regulate down to 10 volts. It could heat up below that. You will have some line loss depending on what wire you use. A battery voltage below 11.5V (just my guess) might create 10V at the controller.
Why not try the one you pointed to on eBay? It's $13 delivered. 25KHz switching frequency so it shouldn't be noisy, rated for 10A and has a power switch. I assume you already have the wires located where you want it on the wall. Did you run 16awg wire? Wires being too small/long could be a problem.
The eBay link one is the closest to what I have, same plastic case (no vent holes), so it will fit right in.
I will have to go investigate what wire. Most of the wire run is big wire, and I do not own any smaller than 18g, but if it is 18 then it is just a small section... However, running fan on a low output speed my guess is 18g wire is not coming into play here.
What Im worried is that I forgot and left the fan on overnight, on a low speed, just fast enough to keep running, and maybe the batteries, 7 yrs old now, got a little lower over night and the fan stopped running, but was getting power sent to it, and sent through the controller still.
I know from audio that when this sort of thing happens to a speaker you can melt the voice coils, low-power can hurt a speaker more than too much. (weak signal to a two-way speaker and the smaller speaker takes all the power, not the big speaker... I wont get into details).
So, I am not sure if it was my fault and I melted something with a non-running fan, or it the controller just died naturally. I dont want to blame the vax if it was truly a natural death sort of thing...
frankwp
Calgary, AB, Canada
Posted: 08/26/21 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
ajriding wrote:
mindless is when people just look up "speed controller" and post a bunch of links, none that are relevant usually.
That Guide to put a controller in is nice, but not anything to do with what I want - to have a controller that uses less energy at lower speeds.
I have my controller feeding the FF, so have control on a wall, not at the fan. I can always put controller at max and run the FF normally. I set FF on High and control the speed by using the controller.
The PWM things have big heat sinks, so are producing heat. IDK beyond that, so am asking any electrical geeks out there who might know
You seem to be contradicting yourself here. The controller in the linked guide is a PWM, as is your controller that burned out. It's about the most efficient speed controller for your fan that you will find. The reason for the big heat sink is so it won't burn out like your old one. You can still mount it remotely from the fan & bypass the local fan switch, or just leave it on high.
And those coils are not "heating elements", they are resistors.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
2112
Posted: 08/26/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Most everything electrical dissipates some wattage in the form of heat, even if it's 1/10th of a watt. There is no free lunch here. It can be such a small amount that the properly designed component in a properly designed circuit doesn't heat up enough to notice, if at all.
The MOSFET transistors have heat sinks because they are capable of passing 15A at 95% duty cycle. That's probably about 8 watts. The controller is designed to handle worse case. But you are only drawing 3 amps or less. The transistors might dissipate a watt or less with the fan running full speed. When you slow it down that wattage dissipation goes down. That's the beauty of a PWM controller. If your knob is turned down half way you are using 50% power, creating less heat.
2013 KZ Durango 2857
ajriding
st clair
Posted: 08/26/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the answer... This is more the discussion I am interested in. So, the heat sink on a PWM is to keep the electronics cool, not to burn off heat in any way to reduce fan speed...
Sounds like the pwm is the way to go for efficiency at least.
The one I had did make noise, and I have heard others mention the ringing noise from the pulses, so might not be a bedtime item... At night I can just use a clip fan.
Also, a heating element is a resistor, thats why it works. The FF uses these "things" to waste electricity. I don't have an amp meter to test how much though.
* This post was edited 08/26/21 06:26pm by ajriding *
Posted: 08/27/21 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Ok, how do PWM converters work and how do DC-DC converters work?
PWM's are ON/OFF there is no "Half on" the ratio of ON to OFF is what decides speed. as a result they dissipate very little power themselves. So they don't get all that hot.
DC/DC converter come in two types. buck only and buck boost.. I suspect the buck only are PWM with a filter cap on the output... Again very very very low power dissipation Don't mean they should not feel a breeze.. just means they do not get all that hot.
2112
Posted: 08/27/21 06:20am Link  |  Quote  |  Print  |  Notify Moderator
A heating element is designed to produce a certain amount of heat at a certain voltage. They are generally made of materials that can glow red hot without failing. It does have a defined amount of resistance to work properly but generally they are not used in a circuit to serve as a resistor. Think of the heating element in your electric water heater. It has about 10 ohms of resistance but why would you use that as a 10 ohm, 1000 watt resistor? Plus, it would have to be submerged in water or it will cook itself and fail in seconds.
The air core wire wrap resistors on your fan were designed to be used as low resistance, high wattage resistors. You could probably use them as a heating element if you stay within there design parameters. Their datasheet would define their thermal characteristics and other parameters you would have to adhere to. There are other resistors they could have used that look more like resistors. They probably made the ones they used in-house for cost savings.
Short story: I was designing a 3-phase brushless motor controller years ago that required exactly 40A peak current. I needed a precise milli-ohm level current sensing resistor capable of passing 40A +margin in a small footprint. Tolerance stack-up of other components required this resistor to be tuned. I used large gauge enamel coated wire wrapped similar to your resistors. It may have looked like a heater element but its purpose was to create a precise amount of resistance.
I hope this helps
frankwp
Calgary, AB, Canada
Posted: 08/27/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I hope this helps
Good explanation. Those coils, in the context of the FF controller are most definitely not heating elements.
frankwp
Calgary, AB, Canada
Duplicate post
* This post was edited 08/27/21 11:18am by frankwp *
frankwp
Calgary, AB, Canada
Posted: 08/27/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I know you don't want links, but you're going to have to put some effort into this yourself because we don't know what your precise requirements are. You'll find a good selection here:
Aliexpress
Be aware that current ratings are frequently overstated & choosing something that is rated for 2x the fan current would be reasonable.
* This post was edited 08/27/21 11:16am by frankwp *
Page of 5
 > Fan Speed Control
