RV.Net Open Roads Forum: Dually swing out Jack not locking into position?
 > Dually swing out Jack not locking into position?
joe&julie81
Cleveland, TN
Posted: 08/24/21 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Once the tc is sitting on the truck and the dually swing out jacks are no longer supporting the weight they should fold in and lock close in and parallel to the bed of the truck. To release them to swing out again involves pushing a spring bolt on the bottom of the hinge. Just recently one of mine stopped clicking into the locked position when pivoting it inward, as before. Do I need to loosen or tighten the spring bolt? Or what do I need to do to keep it from flopping around and hitting the truck when driving?
04 Dodge 3500 dually, HO CTD, 6 spd NV5600, 4.10 anti-spin rear axle; 2018 NorthStar 950sc with 320 solar, sub-zero package, compressor fridge, torklift tie downs
fpoole
PNW and Beyond
Posted: 08/24/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, had the same Problem-O.
They stick.
There's a brass? pin at the top that catches in the slot.
I have to tap them to open and close. The spring at the bottom sticks too..
Tried to lube it but didn't do much...
I just carry around a rubber mallet on each side to tap it..
Hope that helps...
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10ā€™ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow Nā€™ Go, E-Bike
RS1 Buggy
frank
Pooles website
joe&julie81
Cleveland, TN
Posted: 08/24/21 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
I'll try that, thanks.
tlowe43q
NH
Posted: 08/25/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
I found one of my pins very slightly bent ā€¦ impact damage? I removed the pin and lightly filed and used crocus cloth to improve the fit. Thereby, I avoided needing to tap the pin up & down into lock.
rutzbeck
Haines, AK
Posted: 08/26/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Mine do that. I just push down on the top and then wiggle the jack at the same time and it works into place. I was told once to pull the pin and scrub it with brake fluid getting off the rust. I then lubed it with WD 40. That worked but it started doing it again in a couple of months and found the wiggling worked fine, so I have just stayed with that.
HMS Beagle
Napa, California
Posted: 08/26/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
WD40 will ge gone in a couple of weeks. If you have it apart, clean it up and grease it with some heavy grease.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
