RV.Net Open Roads Forum: Rusty grille - How to avoid
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > Rusty grille - How to avoid
BobsYourUncle
Calgary Alberta Canada
Posted: 08/25/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
I am very fussy about cleaning my BBQ grille after every use. It has your typical cast iron cooking surface.
I clean it thoroughly, scrape off excess food, burn off all residue and follow that with the wire brush treatment until it is clean.
Challenge is, the grille rusts, especially after spending the winter stored in the pass through compartment.
Before each use, I thoroughly wire brush it again to get rid of any old remnants and then brush on olive oil with a silicone brush on the entire surface. Then I burn off the excess oil until I have a hot, rust free surface to cook on.
There must be something that can be done to avoid the rust. Leaving a dirty greasy layer of old dead food does not appeal to me. My home BBQ has a stainless steel grille and it's easy to keep clean.
What do you guys do?
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
bgum
South Louisiana
Posted: 08/25/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I leave a dirty greasy layer of old dead food and when I do clean it off no rust.
pianotuna
Regina, SK, Canada
Posted: 08/25/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Spray with Pam before each use.
Don't clean it so fastidiously. Don't burn off the olive oil.
If the cast iron grill will fit in an oven, you can season it the same way as a cast iron frying pan. Use a "high heat" oil such as walnut.
Regards, Don
Super_Dave
Harrisville, UT
Posted: 08/25/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
For me, the heavy scrap and clean is before each use. Preheat the grill on high and stuff comes off easily, no rust.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
valhalla360
No paticular place.
Posted: 08/25/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Treat it similar to seasoning a cast iron pan.
- Yes, you clean off the food residue after each use.
- You do not do a deep clean...particularly avoid soap.
- While still hot, oil it, so the oil gets pulled into the pores when it cools and leaves a light layer on the surface.
As long as it doesn't get wet in storage, that should largely eliminate rust.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bob213
Fresno, CA
Posted: 08/25/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
I would clean it and then put a light coat of oil on it. That's what I do to my Blackstone and it does not rust.
2112
Posted: 08/25/21 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
I was having this problem with my smoker I use maybe twice a year. Its grill is flat expanded metal, not even cast iron. I've been covering the grill with an old bath towel soaked in cheap $ store vegetable oil for several years. Problem solved. And yep, that old bath towel smells horrible, but no rust.
With the price of brisket these days I don't know when I'll use that smoker again.
2013 KZ Durango 2857
magnusfide
On the Road Again and Again and Again...
Posted: 08/25/21 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Double ditto. I don't use olive oil as it has salts in it that cause rust. Cheap vegetable oil or lard with no salt is advised.
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Bacon is the duct tape of the kitchen.
Magnus
BobsYourUncle
Posted: 08/25/21 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the thoughts everyone.
I shall take them to heart! [emoticon]
miltvill
Ft. Lauderdale FL
Posted: 08/27/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I grill/BBQ almost every day. Over the past 45 years I have had many cheap gas grills, 3 charcoal and one smoker. The worst thing you can do to a grill with cast iron grates is to burn the food off after cooking and not seasoning the grates for the next use. I never clean my grill after use. I clean my grill when I am going to use it and season the grates. However, if you don't cook as often as I do then clean the grates after you cook and oil the grates. I live in a hot humid place so I now have a Weber Geneses III gas grill with heavy stainless steal grates (expensive but worth it). For my 34 year old Weber charcoal grill and smoker every few years I replace the grates. I will not have another grill with cast iron grates. I have also had grills with cast iron burners that did not last 2 years. I do love my cast iron pans.
2020 GMC Denali\Duramax 3500HD Dually Crew Cab
Sold-Trail Cruiser TC23QB
