RV.Net Open Roads Forum: Truck Campers: Do pass-through windows leak?
 > Do pass-through windows leak?
JoeChiOhki
Sauvie Island, OR
Posted: 08/25/21 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
I suppose it depends on the model of window and the quality of the install. I added one on my restoration, reusing a rear window from another camper that was already known to be able to handle road spray.
I do plan to get the foam boot to go around it, as I'm hoping to convert the rear window on my truck to a slider type from the current non-slider glass that is in there now.
Its vastly too small for a person to do anything with, but its more than large enough for air flow and to allow for the locating of the cat's enclosed litter box on its platform behind the seats in the cab when the camper is parked for the night so that its out from under foot.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
joeshmoe
So Cal
Posted: 08/25/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Mine leaks somewhat in driving rain, but that doesn't happen often. Usually put a towel down.
The PDI tech warned me it might leak. He said they generally install a solid pane, one-piece glass if its really bad.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
dhull
Some Lake Some where
Posted: 08/25/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Ours leaked, Wolf Creek 840, had sliding window that leaked while driving in downpour. Replaced with a one piece. Sure do miss ability to vent in fresh air from there.
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 08/26/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
stevenal wrote:
Covered by the cabover and inside the draft of the truck cab, this is our preferred window to keep open for our pets' comfort in all weather but dust.
I agree - this is my "go to" window for ventilation during a downpour!
bighatnohorse
Gig Harbor - Cave Creek
Posted: 08/26/21 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info - we rarely drive in heavy rainfall and that could be a reason for no leaks.
I think the manufacturer is cost cutting - eliminate the cost of a sliding window - and keep the sale price the same = more profit.
Besides, how many people have a cat or dog that use the pass through window? Or need fresh air circulation in any weather?
I've custom ordered a 15" x 30" pass-through window to replace the factory fixed glass.
Waiting for delivery now. . .
EYEMLOST
See Above
Posted: 08/26/21 08:39am Link  |  Quote  |  Print  |  Notify Moderator
1998 FWC Granby
The 15 year it spent being towed on a HMMWV trailer: Zip/zero/nada leaks.
Since being mounted on my '94 Bronco: Zero leaks.
1998 FWC Grandby
1994 Ford Bronco 5.0 XL 4X4
Sky's ORD 6" Lift / Sterling 10.25 Dually 5.13 Gear Detroit Locker / '99.5 Front F-350 Leaf Springs at Rear / HMMWVtires
EYEMLOST
See Above
Posted: 08/26/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
How do you know it's "more profit"???
The cost of doing business also goes up......
deltabravo
Spokane, WA
Posted: 08/27/21 06:06am Link  |  Quote  |  Print  |  Notify Moderator
One manufacturer in particular is telling it's dealers that they stopped installing pass-through windows that open because the window leaks.
If I left a roof vent open slightly while traveling in the rain (I had a vent cover on it) the window below the cabover didn't leak.
The one time I drove with the vent closed, the window leaked.
The problem is that a vacuum gets created when going down the road, if all vents are closed. The differential in air pressure sucked water in through the sliding window track on that front window.
The dealer described this to me when I told them about the leak.
After that trip I replaced the window with a solid window from Motion Glass in Vancouver, WA. They custom build windows.
Nope. That manufacturer really did ditch that slider due to so many customer complaints about it leaking.
I've heard this from the factory.
It's actually water coming in through the window track, not the quality of the installation of the window.
JoeChiOhki
Sauvie Island, OR
Posted: 08/27/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
There's been more than one thread over the years on here where folks had to get replacement windows because the assembly of the original window was so poor that it was like having nothing more than a window screen in place.
Throw in the slap in and done construction quality of most RVs these days, if its not the track leaking, its the butyl tape (or lack there of) around the window allowing water to also infiltrate into the frame.
Bedlam
PNW
Posted: 08/28/21 08:45am Link  |  Quote  |  Print  |  Notify Moderator
My Arctic Fox window leaked only once and it was due to driving rain from the side. The two trucks I had with sliding windows did not leak.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
