RV.Net Open Roads Forum: Class A Motorhomes: Air Bag issue
 > Air Bag issue
Colo Native
Colorado
Posted: 08/25/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
I have a huge problem I had a rear air bag fail to inflate and hold air, I ordered new rear bags but they won't be shipped now until Sept. 30th and my rig is broke down in South Dakota and I am in Colorado, so far the place I was at in SD has let me keep it there till the parts come in well they were suppose to be here today (**** Covid). Is there any way to inflate the bag and keep it that way so I can bring it home? Or am I screwed. If not I have to drive up there and winterize it too.
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
jdc1
Rescue, Ca
Posted: 08/25/21 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Why not just call a local Firestone shop and see what they have available?
Colo Native
Colorado
Posted: 08/25/21 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
There is a nationwide shortage.
MountainAir05
New Mexico
Posted: 08/25/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Since you did not list the make or model/year its impossible to help you. If the bag will not hold air, no you can not inflate it. You do not have to get it ready for winter yet. I assume you check or had it checked and the bag was the issue, not a valve or air line/connector.
wolfe10
Posted: 08/25/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
We have no idea what part is leaking.
Is it the actual air bag itself? Unusual at that young age unless damaged by road hazard, etc.
The air fitting to it?
The ride height valve?
Other?
* This post was edited 08/25/21 03:44pm by wolfe10 *
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Bikeboy57
Inverness, FL
Posted: 08/25/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
If it is indeed an airbag, you can raise the coach with a bottle jack, and make wood inserts to put into the suspension. The weight should go across the grain. Use treated lumber. Disconnect and plug the airline to the height control valve. If the coach has a tag, it will need support also. It will ride like a wagon, it will get you out of SD.
Richard and Rhonda
1999 Newell
Subaru Outback toad
crawford
Dandridge Tenn.
Posted: 08/25/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
See our large selection of New & Used RVs at ColawRV.com
Try these people big company
Change from a c class to a A class Georgetown 07 triple slide
Colo Native
Colorado
Posted: 08/26/21 08:35am Link  |  Quote  |  Print  |  Notify Moderator
It's in the sig
Colo Native
Colorado
Posted: 08/26/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
No air bags
Colo Native
Colorado
Posted: 08/26/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Have you actually done this?? There is no height control valve that I am aware of.
 > Air Bag issue
