RV.Net Open Roads Forum: Class A Motorhomes: Air Bag issue
 > Air Bag issue
MountainAir05
New Mexico
Posted: 08/26/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Colo Native wrote:
MountainAir05 wrote:
Since you did not list the make or model/year its impossible to help you. If the bag will not hold air, no you can not inflate it. You do not have to get it ready for winter yet. I assume you check or had it checked and the bag was the issue, not a valve or air line/connector.
It's in the sig
2015 Winnebago Forza 34T
Thank you. I do not see a signature on my view.
dougrainer
Carrolton, Texas
Posted: 08/26/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
It's in the sig
Can you not access his "View Profile" ? That has his sig. Doug
dougrainer
Carrolton, Texas
Posted: 08/26/21 09:55am Link  |  Quote  |  Print  |  Notify Moderator
You stated NEW bags on backorder. Is your problem the one air bag will accept air but has a hole? What did the Service Center diagnosis the problem as? Doug
Bikeboy57
Inverness, FL
Posted: 08/26/21 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Yes i have actually done this. My coach weighs 53K, significantly more than the Forza. I lost an innner drive tire which took out an airbag and the height control valve. My rig sits on the tires if the air bag is not inflated so i could not be towed. I was on the side of I 40 and had to get the coach to a safe place.
Richard and Rhonda
1999 Newell
Subaru Outback toad
 > Air Bag issue
