RV.Net Open Roads Forum: General RVing Issues: Hot water tank drain plug
 > Hot water tank drain plug
morley
British Columbia
Posted: 08/25/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone, hope that all is well with each of you out there.
Due to some emergency brain surgery a month ago, our camping season sadly has come to an abrupt end.
We are in the process of cleaning out and winterizing the 5er for winter storage. While I was draining the hot water tank, I got to thinking there must be a better way than having to remove this hard to get at plastic plug ever year to drain the tank.
I thought that I had heard of some types of plugs with a flexible pipe on them and a valve at the end that can just be opened and the tank drained without removing the plastic plug.
Any one have or seen or know if such a thing exists?
Won’t need it this year. But years into the future if my health allows and we can continue RVing we would like to use this type of arrangement at seasons end.
2008 Topaz F254SS 26 ft.
2009 Chevy Silverado, 2500HD, Duramax, Allison Tranny, 4x4, EC
250 watt solar panel system, BlueSky controller and remote
Mfan
Otsego,Mi
Posted: 08/25/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Google hot water drain plug. Take your pick
enblethen
Moses Lake, WA
Posted: 08/25/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Some people have used a stainless flexible supply pipe, a 1/2 inch nipple into tank and a 1/4 turn ball valve.
Drain plugs are easy to get out with proper sized socket on an extension.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Monterey, California
Posted: 08/25/21 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
The larger plastic plug provides more complete drainage IMO. I agree with enblethen…proper socket…easy to do.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
capacitor
California
Posted: 08/25/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
What make is your water heater? If it is a Suburban, the drain plug is the anode rod and is not plastic. If so, someone has messed with it. Get an anode rod and a 1 1/16” socket and do it right. You will damage the tank without one,
If it is an Atwood, then a drain with 1/4 turn valve may work.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 08/25/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
The issue with any type of drain fitting is the junk buildup in the tank will plug that small hole. Part of draining is it gives you the chance to flush the **** out of the tank to help prolong it's life.
You could take that cheap plastic plug to a plumbing store and get a metal plug and when installing use teflon tape.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
bob213
Fresno, CA
Posted: 08/25/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
The plug on your water heater is made of nylon for a reason(galvanic corrosion). Don't change that. If you change anything make sure the connection to the tank is still nylon or the metal your tank is made of.
Traver8
West TX
Posted: 08/25/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I found a replacement nylon plug for my Atwood at Tractor Supply for a VERY reasonable price - under $2 if I remember correctly.
craig7h
Branson MO area
Posted: 08/26/21 02:33am Link  |  Quote  |  Print  |  Notify Moderator
When I got my used coach the past owner replaced the nylon plug with a brass set up that included a petcock to drain the tank. The first chance I got I replaced it with the good old nylon plug. The reason I could not clean out the tank. At the end and beginning of each season I like to really flush out the tank to remove any debris.
Itasca Meridian SE 36g
Road Master Tow Dolly
Posted: 08/26/21 04:30am Link  |  Quote  |  Print  |  Notify Moderator
The problem is that tank is made of a metal that does not care for several other metals like brass.. I've used the proper PLASTIC tube to a metal quarter turn valve.. I did that twice. first one worked, 2nd one leaked.
