RV.Net Open Roads Forum: Tech Issues: Inverter question
 > Inverter question
Teleman
Clayton, CA, USA
Posted: 08/26/21 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Trust me this is the easiest solution. I can charge the eBikes while driving without using the generator. We are always on the move from one riding destination to another. We are hardcore mountain bikers and we don't stay put in one place very long. At some point we will install a solar system but this is working for us pretty well.
Teleman
Clayton, CA, USA
Posted: 08/26/21 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
Ok let me better explain this. We got along fine without an inverter until we got the e-bikes. I bought an 1100 w inverter to charge the e-bikes and simply planned to run an extension cord from the inverter which is near the house batteries which in this motorhome are under the hood. What I wound up doing was running the extension cord under the chassis in a split loom to the back of the RV where the bikes are on their rack I connect the chargers which are in a mesh bag securely hanging off the seat post on one of the bikes and then connect the magnetic charge plugs to the bikes. This way I can charge the bikes while I'm driving. Otherwise the big batteries in these bikes are a bit much for the two house batteries and will deplete them quite a bit for a full charge. Now since I have the extension cord outlet at the back of the RV it's very close to the shore power cable and easy to plug in simply to run the coffee machine. I've been dripping coffee by hand which is okay but it would be more convenient to just have the machine make the coffee. So I would shut off all the breakers but the kitchen galley where the coffee machine is plugged in. No big deal and not worth it for me to be wiring the inverter directly into the breaker box. I understand this is a bit too "Jerry rigged" for some of you but it's cheap and functional so I'm good with it.
ronharmless
The far side
Posted: 08/27/21 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Interesting; is that the definition of a "hardcore mountain biker" in CA - eBikes?
eric1514
AZ ID
Posted: 08/27/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
lol
Here's what I did.
I replaced the existing RV type outlet with a residential one, cut the tabs on the back to isolate them from each other and wired one side to the inverter and left the other side wired as it was. That outlet was always there. If I'm plugged in, I use the shore side. If I'm not, I use the inverter side after turning the thing on with the remote on the wall. No ATS, no plugging or unplugging power cords and no flipping breakers.
2006 Isata Touring Sedan 250
Teleman
Clayton, CA, USA
Posted: 08/27/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
For decades we've pedaled up brutal climbs and rode down gnarly technical descents on traditional full suspension bikes. We just got eBikes to be able to increase our range and time out on the bikes. You're welcome to come along and if you're still game after pushing the 50 lb eBike up one of the unrideable hike a bike sections you'll get to follow us down one of the steep rocky shoots that's really just a boulder infested dry stream bed.
Teleman
Clayton, CA, USA
Posted: 08/27/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
eric1514 wrote:
lol
Here's what I did.
That's very nice and a lot more work than I want to do.
Also the nearest outdoor receptacle is 15 feet from the rear of the RV where the bike rack is. My extension cord ends right at the foot of the ladder where it's convenient to plug in the chargers.
* This post was edited 08/27/21 08:39am by Teleman *
BFL13
Victoria, BC
Posted: 08/27/21 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure the receptacles you want to use are not on the same breaker as the converter, which is sometimes the case in RVs. If they are you can change that without too much work.
Using the shore cord to an outside inverter instead of using an extension cord to inside means no mosquitoes getting in the window left open for the extension cord.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Teleman
Clayton, CA, USA
Posted: 08/27/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
The converter breaker is shared with the bedroom. The kitchen is on a separate breaker and the only one I would leave on.
 > Inverter question
