RV.Net Open Roads Forum: Tow Vehicles: Airbags and Compressor and Tank
Search only in Tow Vehicles
 > Airbags and Compressor and Tank
blaczero
Posted: 08/26/21 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking for a way (I cannot be the first person) to have a compressor that airs up my airbags and also has a port to plug a hose into for airing up my tires.
I get the concept of having a nice compressor and tank attached to my frame, but what controller would I put in between the tank and the bags?
Monterey, California
Posted: 08/26/21 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
First item to fail on an air bag system is the pump. I use a bicycle pump. Easy, quick, replaceable.
jdc1
Rescue, Ca
Posted: 08/26/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
A simple manual on/off valve.
IdaD
Idaho
Posted: 08/26/21 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
There are onboard air systems for exactly what you're wanting to do.
Example
2015 Cummins Ram 4wd CC/SB
2112
Posted: 08/26/21 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
This Guy did a real clean install on his TC. Maybe you can get some ideas from this. I like how he located his air intake and hose QD in the cab.
2013 KZ Durango 2857
C Schomer
Pueblo West, Co.
Posted: 08/31/21 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Anything goes as far as a valve and gauges. I ran a tube from the tank to the back of the truck so I can connect a hose for tires. Craig
Posted: 08/31/21 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
That was helpful....
2017 Heartland Torque T29
Posted: 08/31/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
There are pneumatic control panels if you have the air source available (ie your onboard air system), for about $200 Firestone makes them. If you want in cab airbag control.
That's about the simplest and cheapest unless you pieced one together.
